RAW images as the name says.. they are untouched. when you click pictures they are saved in formats like jpeg and all... RAW is also a format like that.. in other formats pictures you click get compressed and loose their detailing.. while as in RAW the picture will be untouched,it is neither compressed nor its gonna loose detaling... i hope you understood this..
now in oneplus 3/3T you can click RAW images,but not with stock app.. you need some third party app installed that have that feature..
if you really want to click RAW pictures.. here are the steps
1.you need to unlock your bootloader and install TWRP
2.
https://www.mediafire.com/download/5mch70kqd39anh1
3.
https://www.mediafire.com/download/ppb4tybk7stqcwl
4. download 2&3 (2 is the zip file you need to flash,dont extract)
5. flash the zip file(2) via twrp
6. reboot your phone to system
7. install the apk(3)
8. open the app and set the settings to the attached screenshot.
9.ummm... done [e]1f601[/e]
Peace[e]270c[/e]️
