53
Guide re-calibrating accelerometer, magnetometer & gyroscope sensor
  1. Gaurav Rohilla
    Lollipop Nov 14, 2015
    Gaurav Rohilla , Nov 14, 2015 :
    STEPS TO CHECK WHETHER THE SENSOR'S ARE CALIBRATED OR NOT
    -open dialer,
    -enter *#808# to explore all HARDWARE related tests,
    -scroll down and tap on G-SENSOR test,now,place your phone in
    LEFT-HORIZONTAL-VERTICAL POSITION( ideal angle should be 270 degree)
    RIGHT-HORIZONTAL-VERTICAL POSITION(ideal angle should be 90 degree)
    VERTICAL POSITION(ideal angle should be 0 degree)
    P.S 2 or 3 degree's more or less than the ideal angle doesn't matter
    now, if the angles you got varies abruptly with the ideal one's, this guide will be useful for you.
    CALIBRATION NOW BEGINS
    -from the same test's list, tap on SENSOR SELF TEST & CALIBRATION which is right above the G-sensor test.
    - there'll be 3 sensor's present up in that list:
    1. ACCEL: LIS3DSH Accelerometer
    2.MAG: MMC34160PJ MMC34160PJ
    3.GYRO: L3GD20 Gyroscope
    now, tap on 1st test. if you get Test FAILED. Error: Device Busy ( if you're not getting this error, follow the guide from START till END) as the result , then here's the solution for it:
    - open PLAY STORE >> settings >> Auto-update apps (under general) >> select "do not auto-update apps".
    - settings >> security >> device administrators(under device administration) >> uncheck " Android Device Manager".
    -settings >> apps >> "Google Play Services" >> DISABLE.
    -Restart your phone,
    -NOW,
    START PLACE YOUR PHONE IN STRICT HORIZONTAL POSITION ON A PERFECT STABLE HORIZONTAL SURFACE
    -tap on each test for about 9-10 times ( this will re-calibrate the sensor's).
    - again go back to "G-sensor" test to confirm the new angle's.
    -you're all done :) END
    -again go back to "device administrator" and check "Android Device Manager".
    -update "Google Play Services" from the given link : https://play.google.com/store/apps/details?id=com.google.android.gms&hl=en
    -again go back to "Play Store" and choose the app's update type as per your preference.
    WIPE SYSTEM CACHE after everything is been done
    ALTERNATIVE METHOD FOR DEVICE BUSY ERROR (HARD RESET REQUIRED)
    -switch off
    -press power button+vol down , till phone vibrates ,then release them
    -choose English language
    -advanced
    -format data, choose yes and format it
    -reboot
    now, while setting up your phone "SKIP THE GOOGLE SIGN-IN PAGE" and proceed further. the moment you reach at home screen :
    - open
    PLAY STORE >> settings >> Auto-update apps (under general) >> select "do not auto-update apps". (this should be done like crazy fast. if your phone is connected to wifi or mobile data, then please disable them).
    now,open *#808# menu >> SENSOR SELF TEST & CALIBRATION: then follow the same guide lines from
    START till END.
    -sign-in to your google account.
    -update your phone and ENJOY!:)
    THANKS FOR READING. HAVE A NICE DAY:)
    RELATED THREADS:
    https://forums.oneplus.net/threads/motion-sensor-issue.358518/
    https://forums.oneplus.net/threads/rotation-sensor-calibration.358538/#post-13023065
  2. pgidia
  3. Peterxxx
    Ice Cream Sandwich Nov 14, 2015
    pgidia, pa5t1s, Ceasedd and 1 other person like this.
  4. aaron.hossain75
    pa5t1s, sunilbagalur, Ceasedd and 2 others like this.
  5. Gonzo01
    Gonzo01 , Nov 14, 2015 :
    good job. :)
  6. Tokolozi
    Most Original Avatar Nov 14, 2015
  7. wea3el
    Honeycomb Nov 14, 2015
    pgidia and Gaurav Rohilla like this.
  8. Gaurav Rohilla
    pa5t1s, Ceasedd and pgidia like this.
  9. Manas Eapen
    Jelly Bean Nov 14, 2015
  10. wea3el
    wea3el , Nov 14, 2015 :
    No, Oneplus One, I haven't noticed I'm on Two's part of the forums xD
    So, any advice for One users?
    My compass is off in Here maps.
  11. Gaurav Rohilla
    never owned the one buddy. sorry, can't help :(
  12. wea3el
    It's ok.
    Great guide for Two owners!
    Cheers
  13. ratification
  14. butaixyz8016
  15. pgidia
    pgidia , Nov 14, 2015 :
    Mine best friend have to comment it first
  16. Hafiz5635
    Hafiz5635 , Nov 14, 2015 :
    Test PASS for me..
    Ceasedd, Gaurav Rohilla and pgidia like this.
  17. Hafiz5635
    Download compass app in play store separately.
    Gaurav Rohilla and wea3el like this.
  18. Bartnl
  19. Gaurav Rohilla
    sunilbagalur, Ceasedd, wea3el and 2 others like this.
  20. Gaurav Rohilla
    Lollipop Nov 15, 2015
