53
Guide re-calibrating accelerometer, magnetometer & gyroscope sensor
  1. Gaurav Rohilla
    Lollipop Dec 3, 2015
    Gaurav Rohilla , Dec 3, 2015 :
    awesome :D
    #61
    ajkaramba and pgidia like this.
  2. B Boy NIcky 18+
    Froyo Dec 6, 2015
    B Boy NIcky 18+ , Dec 6, 2015 :
    awesome sir. :)
    #62
  3. abdulwasay
    Eclair Mar 30, 2016
    #63
    pgidia and Gaurav Rohilla like this.
  4. Gaurav Rohilla
    Lollipop Mar 30, 2016
    #64
    pgidia and abdulwasay like this.
  5. siavoch
    Cupcake Apr 8, 2016
    siavoch , Apr 8, 2016 :
    I have a question,
    It really worked but my proximity sensor doesn't work.
    What's the solution?????
    #65
    Gaurav Rohilla likes this.
  6. Gaurav Rohilla
    Lollipop Apr 8, 2016
    Gaurav Rohilla , Apr 8, 2016 :
    did you try reflashig the OS?
    #66
  7. siavoch
    Cupcake Apr 8, 2016
    #67
  8. Vishal Anjana
    Gingerbread Apr 10, 2016
    #68
  9. merewoodbebox
    Jelly Bean Apr 10, 2016
    #69
  10. aaron.hossain75
    Lollipop Apr 10, 2016
    #70
  11. Gaurav Rohilla
    Gaurav Rohilla , Apr 10, 2016 :
    do this stuff on oxygen and then flash another custom ROM. actually, the secret code "*#808#" doesn't work on any ROM except oxygen os.
    #71
  12. merewoodbebox
    merewoodbebox , Apr 10, 2016 :
    will try now, but im sure it doesnt stick through flashes
    #72
  13. merewoodbebox
    DUDEEEE IT WORKED OMG THANKS
    #73
  14. Gaurav Rohilla
    #74
    merewoodbebox likes this.
  15. Gaurav Rohilla
    Lollipop Apr 26, 2016
    Gaurav Rohilla , Apr 26, 2016 :
    I guess ( also told by oneplus staff member) the cause of FPS dead is because of Google play services. and the same is also been confirmed by @GerardTB :
    you can try this if in case the FPS isn't working.
    #75
  16. cybreed
    Honeycomb May 7, 2016
    cybreed , May 7, 2016 :
    Im running the 6.0.1 beta this morning the FP & home button stopped working, whole afternoon during the button test in *#808# menu, all button work except HOME. So I just enabled on screen nav a while so at least can use the phone. moments ago, I did the tests again and HOME works, just to clear the tests, seems quite random. hopefully this issue will be resolved soon
    #76
  17. Lancelot_69
    Lollipop May 7, 2016
    #77
  18. Gaurav Rohilla
    #78
    Lancelot_69 likes this.
  19. Gaurav Rohilla
    Gaurav Rohilla , May 7, 2016 :
    this is a very known issue. reflash oxygen os 2.2.1 and see if works. if it still doesn't works on oos 2.2.1 , go for RMA/service center depending on your country.
    #79
    cybreed likes this.
  20. cybreed
    Honeycomb May 8, 2016
    cybreed , May 8, 2016 :
    Will give it ago once i download 2.2.1, Just as long as its not hardware issue.
    thanks @Gaurav Rohilla for the peace of mind.
    #80
