53
Guide re-calibrating accelerometer, magnetometer & gyroscope sensor
  1. cybreed
    Honeycomb May 20, 2016
    cybreed , May 20, 2016 :
    Just checking in to say that my FPS/home button came back to life.
    After prev posting, I enabled on screen Nav and have been using it since. But I also enabled the home button just in case it decided to come back to life. I had set double tapping to turn on the camera. 2 days ago, as I always do I double tap hoping to see the camera turn on and it did. Successively few times in a row. I turn off on screen nav, added fingerprint and so far, no issues.... HMmmmmm....
    #81
    Gaurav Rohilla likes this.
  2. Gaurav Rohilla
    Lollipop May 22, 2016
    Gaurav Rohilla , May 22, 2016 :
    awesome
    #82
    cybreed likes this.
  3. Andrewdotlee
    Eclair May 24, 2016
    #83
  4. Gaurav Rohilla
    Lollipop May 24, 2016
    #84
  5. pabloXX
    Cupcake May 25, 2016
    #85
  6. joesweeney413
    Jelly Bean May 25, 2016
    #86
  7. Gaurav Rohilla
    Lollipop May 26, 2016
    Gaurav Rohilla , May 26, 2016 :
    recovery>>wipe data and cache>>wipe only cache>>reboot.
    #87
  8. TheRealProcyon
    Jelly Bean May 29, 2016
    #88
  9. Gaurav Rohilla
    Lollipop May 29, 2016
    #89
  10. Andrewdotlee
    Eclair Jun 2, 2016
    Andrewdotlee , Jun 2, 2016 :
    Can you install the Oxgen dialer on CM? I've had a look around and can't find it
    #90
  11. Jeroen123456
    Cupcake Nov 12, 2016
    Jeroen123456 , Nov 12, 2016 :
    Hey, I have a oneplus 2 with the latest OxygenOS Version 3.1.0. When I dial *#808# I get the message "Unknown application". Is there any other way to recalibrate the tilt sensor? I also tried recalibrating with the "bubble level" app which works in the app but it doesn't recalibrate the sensor system wide. Also my tilt sensor is about 30-35° off which is quite annoying when playing games or using VR.
    #91
  12. PacoCT
    Cupcake Mar 3, 2017
    PacoCT , Mar 3, 2017 :
    Thank you very much. I has been looking for this for a couple of hours.
    Worked nicely for my 3T
    #92
  13. leveskockaa
    Honeycomb Mar 19, 2017
    #93
  14. vasaxter
    Eclair Mar 21, 2017
    vasaxter , Mar 21, 2017 :
    OP3T here.
    I also ran into off angle problem (camera horizont level) and this is only solution which help.
    The first part worked, so I'm happy not to use second method.
    BTW using GPS status (and similar) to calibrate did not work on system level.
    Note: If you tried to calibrate this in app and the you calibrated it on system level, reset or re-calibrate the apps.
    #94
  15. BrunoNRG
    Ice Cream Sandwich Apr 11, 2017
    BrunoNRG , Apr 11, 2017 :
    @Gaurav Rohilla
    I bought my OP2 five months ago, I did everything as you mention on the first post, but I still have screen rotation issues almost every day (it's fixed after a reboot, but it always comes back), OnePlus said this was caused by Nova Launcher, but it's not true, as the screen rotation problem happens even if I only use stock launcher and after a factory reset / disable auto update / *#808# / calibrating sensors, etc...
    I get the "Test FAILED. Error: Device Busy" message when calibrating accelerometer after updating Google Play Services, any idea how I can get the screen rotation permanently working without having to reboot my phone all the time?
    I've read some post of yours, from 2015, saying this was a bug related to an OxygenOS OTA update and that it would be fixed in a future OTA, almost two years have passed, still no fix or is this a hardware related issue and it's only fixed if some internal part is replaced?
    Thanks!
    #95
  16. F_Sumit_Vishwakarma_JXGT
    Cupcake Apr 11, 2017
    #96
  17. Chetzjain
    Gingerbread Apr 12, 2017
    #97
  18. doc.sniper
    Cupcake Jun 25, 2017
    doc.sniper , Jun 25, 2017 :
    Is there any way to do this system wide calibration with LineageOS installed ? (the 808 dialer thing isn't available there)
    #98
  19. marinobiagio
    KitKat Jul 3, 2017
    marinobiagio , Jul 3, 2017 :
    #99
  20. Vinc098
    Froyo Jul 6, 2017
