518
RE: Yellow Screen
  1. HappyTroll
    Aug 25, 2014
    superchinook and willy_resumed like this.
  2. Mihail_Ko
    Jelly Bean Aug 25, 2014
    Mihail_Ko , Aug 25, 2014 :
    Wat I mean:
    We shouldn't decus to different issues in the same thread! It is confusing!
    And lead some people to believe that they are the same issues, ore all list have the same origin!
    At yo
    It don't mean that people should stop taking about bad things, just to not upset each other.
  3. Royboy
    Ice Cream Sandwich Aug 25, 2014
    Royboy , Aug 25, 2014 :
    Isn’t it heart-warming when you know that your issues are documented and pending urgent attention?
    superchinook likes this.
  4. youngalliance
    Donut Aug 25, 2014
  5. Mihail_Ko
    Yeah, probably the losing team of that waterbol game must do the RMA now.:D
  6. Ahmed Othman
    Gingerbread Aug 25, 2014
  7. Mihail_Ko
    Wat at you talking about?
    Yellow hue!
    Ore
    Yellow band!
    That's why we need separate threads!
    Ahmed Othman likes this.
  8. Ahmed Othman
  9. Mihail_Ko
    One is software other hardware (ore production) problems!
  10. Ahmed Othman
  11. Mihail_Ko
    Hopefully you'll gat the good one.
  12. Ahmed Othman
  13. Greenas
    Greenas , Aug 25, 2014 :
    so tryed to fix mine yellow band with this one UV flaslight http://www.ebay.com/itm/UV-Ultra-Vi...ping_Hiking_Lamps_Torches&hash=item27d909ad02
    and it did not changed anything with yellowband but right now when i look at the screen while
    On with flashlight (and screen off) i can see dots on the screen (from flashlight leds) that only visible when using UV flashlight, when i dont using it i cant see them and those dots are not visible with on or off screen, so it might be adhesive dryed up only on those dots and changed color from transparen to more visible (only visible with UV)
    by the way i noticed there is oval shape of same color as mine new dots in center of screen with line in middle, guess that is from manufacturer UV light to dry up adhesive in middle.
    sry not to have pic coz its not possible to capture that
    Mihail_Ko and Ahmed Othman like this.
  14. quentin66
    Honeycomb Aug 25, 2014
    quentin66 , Aug 25, 2014 :
    The problem with this kind of lamp is that it don't outputs sufficient power to cure glue.
    In a curing process you'll need at least 30w
    If you want to test with a powerfull uv lamp go at a nail saloon and ask them.
    That's what i'm gonna do today just for the fun because i don't trust it will change anything on mine.
  15. epenricefsp
    epenricefsp , Aug 25, 2014 :
    There are so many posts on this, can anybody tell me if there is an official answer to the yellow band caused by the glue?
  16. Mihail_Ko
    No. Oneplus won't recognize it as an issue.
  17. Mihail_Ko
    They say it is: yellow hue, screen backlight, every device have it ( not my though).
  18. tuckkhai
    Eclair Aug 25, 2014
    tuckkhai , Aug 25, 2014 :
    Just got the phone, I'm seeing the same problem. Saw some thread that it was resolved by itself after 2 weeks. Finger crossed
  19. Mihail_Ko
    Yellow band ore yellow hue one?
  20. sachsach
    Froyo Aug 25, 2014
