518
RE: Yellow Screen
  1. topsales Ice Cream Sandwich Sep 30, 2014
  2. chongswee Jelly Bean Sep 30, 2014
    chongswee, Sep 30, 2014 :
    My one purchased on July come with yellow tint but slowly fade out, my wife purchased on August is perfect.
  3. jkbhso3 Jelly Bean Sep 30, 2014
    jkbhso3, Sep 30, 2014 :
    Lol what if it's similar to the burn in effect in plasma? Just happened on our eyes so that we don't see it anymore. Lol
  4. cnc Honeycomb Sep 30, 2014
    cnc, Sep 30, 2014 :
    That doesn't even make sense.. if the yellow is there, then it's there. a blueish calibration would make the yellow stand out even more, because the rest of the screen is even more blue, but the band is still yellow
  5. BigE1995 Ice Cream Sandwich Sep 30, 2014
  6. reverenddak Ice Cream Sandwich Sep 30, 2014
    reverenddak, Sep 30, 2014 :
    I got my One on Thursday (4 days ago), and it has the yellow band. It doesn't really bother me because it's barely noticeable with normal use. Only when it's dark, and I'm on an all-white page or app do I notice it. I cut it down a lot with this app:
    https://forums.oneplus.net/threads/yellow-band-software-fix-no-uv.100868/
    It's not a unique problem, other brands have the same problem. I do hope it fades after a while, but I'm not sweating it.
    FYI, my device was manufactured September 15 (according to the box) so it's fresh off the line. I would have probably not notice it if I didn't read about it on these forums.
  7. Skf123 Lollipop Sep 30, 2014
    Skf123, Sep 30, 2014 :
    According to OnePlus they all have it
  8. topsales Ice Cream Sandwich Sep 30, 2014
    topsales, Sep 30, 2014 :
    Agreed. They call it a "feature." If yours doesn't have it you have a defective phone.:)
  9. BlueSkies Froyo Sep 30, 2014
    BlueSkies, Sep 30, 2014 :
    I just got mine a few days ago. Build date 9/9/14. I have the yellow band and it's pretty visible and looks like it may be spreading to other parts of the screen. I've already contacted Oneplus for a refund.
  10. Andreagennari Ice Cream Sandwich Sep 30, 2014
  11. Andreagennari Ice Cream Sandwich Sep 30, 2014
    Andreagennari, Sep 30, 2014 :
    Sorry fella, but that's the real way to cure it.. Getting rid of it.
  12. topsales Ice Cream Sandwich Sep 30, 2014
    They didn't close it, they just merged it with this thread.
  13. xbenbox Honeycomb Sep 30, 2014
    xbenbox, Sep 30, 2014 :
    How does that not make sense? Have you tried using the yellow fix posted by Aaah in the Development forum? If you actually tried it, you would know that blue is the color that bests masks the yellow.
  14. BigBeanBurrito Gingerbread Sep 30, 2014
  15. BigBeanBurrito Gingerbread Sep 30, 2014
    BigBeanBurrito, Sep 30, 2014 :
    I can comfirm that not all the OPOs hace the yellow band. I have seen 7 OPOs and some of them are perfect. Usually the ones that are without the band have a display that averall cooler calibration kind of blueish. Not all of the blueish screens are perfect. The few screens that I have seen that had the warmer calibration with the yellow hue all over the screen all have also had the yellow band.
  16. BigBeanBurrito Gingerbread Sep 30, 2014
    Good read from one of the ex devs of CM11S on G+:
    Another update today and a difficult one, possibly the last on this page.
    First of all my apologies for being quiet as you got used to frequent updates and some of you were getting impatient.
    Cyanogen Inc. terminated the contract we had about two weeks ago: I’m out.
    Previously, I was a contractor in the inner circle like an employee.
    Fortunately I managed to finish a proper quality camera calibration for the OnePlus DNG before getting the news, and results of this project started from scratch are pretty good.
    It consists in flat-field correction for vignetting and color cast, dual illuminant color profiling (matrices and DCP), sensor specific levels, tuned sharpening and noise reduction parameters.
    I didn’t got the chance to compare this implementation directly with Nokia Lumia RAW DNG output, but I believe it should be at least comparable and noticeably better than anything else available on Android devices right now (by vendors and third party)
    In conjunction with last gen Sony sensor coupled with a good lens, end results are rather impressive.
    However, before being asked to switch to this eventually great previous task, I started working on a full blown solution to the white point discrepancy between OnePlus one devices displays: the target being standard sRGB white aka D65.
    Which by the way is not yellow, red, pink or something else: it’s white as “standard daylight white” meaning the white we see in nature during an average day, and the same white content creators use on their monitors.
    By monitoring social media and forums after the first people received their devices, it appeared clearly this was the number one priority.
    Not that it was coming as a surprise: instead, it was expected it as it’s resulting of manufacturing tolerances in LCD panels base components. The same thing happen on every LCD out here all categories included, and is dealt with (or not) using calibration.
    Since months I asked to get access to a sample at least 10 devices representing variations of what's coming out of the factory but all in all received only one non-final prototype.
    As you might have noticed, the profile I made based on this unique device got reverted against my recommendation in latest OTA.
    This OTA also showed that apparently several panel revisions were out here, which I couldn’t guess from the limited elements I had.
    Meanwhile, OnePlus customer support answer to unhappy customers has been to adjust the hue in screen color effects to change the white point (which will make every color wrong and by definition keeps the grayscale and white unaffected), and happily use my name in the same reply stating that I calibrated this display.
    All this despite I offered help to contacts I had at OnePlus to submit for proof reading what they would post about display before publishing it after reading numerous incoherences in their forums.
    I’m still assigned this: https://jira.cyanogenmod.org/browse/BACON-702 and not quite sure what should be done about it as I had no contact with Cyanogen Inc since.
    On audio, I started reading documentation in volume but didn’t had time to go further than that.
    All in all, I have no regret as had the chance working with a few great people, and tasks I had were all very interesting and challenging. Some too challenging given the conditions and support.
    Conditions have been challenging too as I was not allowed by US immigration to visit anyone on US territory while I’m in France working from home.
    I also had difficulties adjusting to the schedule with the 9 hours time zone difference, my sleep schedule is now completely ****** ^^, also I've been unavailable for a total of 4 weeks since I started in April, when adjusting to my American fiancée visiting and leaving.
    Another guy is working with Cyanogen Inc. from Europe successfully, so I guess that in comparison I've not been very efficient on this regard.
    So no regret but some missed opportunities.
    I started convinced that the OnePlus One smartphone would be the phone of the year.
    It happened differently, today you still can’t buy it and that’s unfortunate. Your only options are to play a marketing game or order it at a higher price without warranty.
    Maybe later, we'll see.
    Since the beginning with the Android Police interview, http://www.androidpolice.com/2014/0...pand-audio-and-screen-calibration-in-android/ interestingly followed by Koush’s departure interview just 2 days later http://www.androidpolice.com/2014/0...-cyanogen-inc-and-his-return-to-clockworkmod/ I knew my place at Cyanogen Inc. was a bet (on both sides) that would or would not succeed.
    I crossed Cyanogen and CyanogenMod path many times before and I’m sure it will happen again but I’m closing today a chapter and it’s time to move forward.
    All my wishes to Cyanogen Inc. and people working here to succeed in finding reliable partners and their vision to be fulfilled.
    So I already started working on a new project.
    From early results the potential is huge.
    Compared to everything I worked before, this doesn't rely on rooting and black magic hacks disappearing in the next firmware update which encourages me to believe this could be finally the long term viable enterprise I was looking for.
    Today I’m rather optimistic for the future, and if you followed me here it’s likely you will be one of my users.
    My personal Google+ profile:
    https://plus.google.com/ supercurioFrançoisSimond
    Moderation note:
    OnePlus and Cyanogen Inc. names lead to divided opinions, comments on this posts will be actively moderated.
    If you desire to share your thoughts, please be respectful and use wisdom.
  17. amartens181 KitKat Sep 30, 2014
    amartens181, Sep 30, 2014 :
    UV exposure should fix it
  18. amartens181 KitKat Sep 30, 2014
    Try a UV lamp or leaving it in the sun
  19. tuckkhai Eclair Sep 30, 2014
    tuckkhai, Sep 30, 2014 :
    It's still there - just that it doesn't annoy me :) So instead of focusing on its weakness, I focus on its strength. It's such a nice phone for the price tag
    jkbhso3 and wilbarger like this.
  20. tuckkhai Eclair Sep 30, 2014
    Unfortunately, UV doesn't work on mine. However, it did fade away over time
