15
[Submitted] Rear camera not focusing after Android 11 update
  1. P Sai Srikar
    Eclair Aug 20, 2021
    P Sai Srikar , Aug 20, 2021 :
    1. Open Google Duo and video call using rear camera & Try focusing a monitor or document less than 50 cm from camera using rear camera.
    3. open telegram video call and try focusing monitor or document less than 50cm using rear camera.
    4. Open Google Lens and try capturing a document using rear camera.
  2. Ankita_S.
    OnePlus Bug Hunter Staff Member Aug 20, 2021
    Ankita_S. , Aug 20, 2021 :
    We would like to check this further and have got in touch with you via personal conversation for more details.
    Please requesting you to respond to us at the earliest.
    Regards,
    Ankita
  3. KidStevie
    Cupcake Aug 20, 2021
  4. deeneendo
    Donut Aug 20, 2021
    pb0264 likes this.
  5. Dimtri
    Cupcake Aug 22, 2021
    Dimtri , Aug 22, 2021 :
    I'm experiencing the same issue. If needed, I can provide some details as well. Thank you for looking into this.
  6. jaidheesh
    Cupcake Aug 26, 2021
    jaidheesh , Aug 26, 2021 :
    same here facing the same issue.... got the update (android 11) yesterday and the google assistant feature i.e google lens is not focusing on any object properly unlike before the update on android 10. The image is blurry when using the google lens and the picture is not clear. I am not using any other camera apps on my phone other than the default one. Hoping this can be fixed soon by the Oneplus experts.
  7. greyhound89
    Cupcake Aug 29, 2021
    greyhound89 , Aug 29, 2021 :
    I have the same issue on my OnePlus 6 after updating to stable Android 11. Third-party applications seems to have a tough time focusing on anything that is in close range. Cannot focus on text mostly. Screenshot_20210829-095539.jpg
  8. I1598254029204
    I1598254029204 , Aug 29, 2021 :
    Same for me on Oneplus 6. Third-party apps can't focus. Also web pages that try to use the camera.
    For Google Translate the workaround was to to to settings and select Camera 1 (default is Auto) for taking the pictures but many other apps do not allow the user to choose the camera.
    pb0264 likes this.
  9. Saulė A
    Cupcake Aug 30, 2021
    Saulė A , Aug 30, 2021 :
    Hey, same issue here on One Plus 6, noticed on Google Lens and another 3rd party app. Never happened before the update.
  10. lebar
    Cupcake Sep 4, 2021
    lebar , Sep 4, 2021 :
    I also have the same issues since the Android 11 update on my 6T, on both Camera app and 3rd party app used to scan documents.
    As the other posts, it was fine prior to the update!!!!
    Is there a way to revert back to Android 10?, as I would rather have a working camera.
  11. SergeyDerunov
    Cupcake Sep 4, 2021
    SergeyDerunov , Sep 4, 2021 :
    I have same issue with my 6T after updating to Android 11. It's awful, I can't use browser apps with camera for my work
  12. bradpatras
    Cupcake Sep 4, 2021
  13. OnkelM
    Donut Sep 5, 2021
  14. M1528226368327
    Cupcake Sep 5, 2021
    M1528226368327 , Sep 5, 2021 :
    I have the same issues with my OnePlus 6 and Google Lens. The normal camera works fine for me as well.
  15. NITHYANANDHAM
    Cupcake Sep 6, 2021
  16. BejoyS
    Cupcake Sep 6, 2021
    BejoyS , Sep 6, 2021 :
    Just came to report this issue with my OP6T. I use this app called "Magnifier + Flashlight" and since the update, the focusing doesn't work.
  17. gerplusone
    Cupcake Sep 7, 2021
  18. Hover
    Donut Sep 7, 2021
    Hover , Sep 7, 2021 :
    Same issue here, and still no response from OnePlus related to this...
  19. ceajayt
    Cupcake Sep 8, 2021
    ceajayt , Sep 8, 2021 :
    Same issue being faced. Rear camera unable to focus on digital monitor or close items.
    Need fox asap.
  20. ngatia
    Cupcake Sep 8, 2021
    ngatia , Sep 8, 2021 :
    Same issue on OP6T. Started after upgrade to Android 11. Was fine before.
    pb0264 likes this.
