2
Camera Rear Camera not working
  1. ComaAeterna Cupcake Aug 13, 2017
    ComaAeterna, Aug 13, 2017 :
    Can't launch Camera with factory app, it says "unknown error". I have reinstalled software with factory reset many times but it didn't help. After that I installed "Open Camera" app from Play Store and it has opened front camera, but rear still not working. Then I made a hardware test in "Aida64" app, so there I can see only one rear camera module with 20MP, but not two (16MP+20MP). Flashlight doesn't work too. So can anybody help me to solve the problem, or at least let me know if it is a hardware problem?
    Alex_Novak and Sandeep Gulia like this.
  2. varma246 KitKat Aug 13, 2017
    varma246, Aug 13, 2017 :
    clear Data of camera and reboot your device.
    if that didn't solved your issue , contact support.
    https://oneplus.net/support
  3. ComaAeterna Cupcake Aug 13, 2017
  4. naveen98852011 Gingerbread Aug 13, 2017
    naveen98852011, Aug 13, 2017 :
    uninstall other camera apps if installed any.Try a phone reset at last and check if not go to service center
  5. microcargill Froyo Sep 19, 2017
    microcargill, Sep 19, 2017 :
    I have the same problem on my 3T.
    Try:
    1. Clearing the cache and data of the camera app
    2. Factory reset
    3. Flashing the stock ROM
    4. If all options didn't work, contact customer care
