rear camera shaking during picture click
  1. lblokendra
    Eclair Mar 12, 2018
    lblokendra , Mar 12, 2018 :
    after updating to 5.0.4
    I am facing problem when I am trying to capture pic from rear camera screen is shaking....
    I have to restart the phone nd wait...den it works fine...
    but facing problem many times
    Ravi BINAVAT likes this.
  2. Romain_Daudin
    Gingerbread Mar 12, 2018
  3. F_Agas_J_Selas_hsLB
    Cupcake Mar 13, 2018
  4. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Mar 13, 2018
    NeVeR_SeTTLe , Mar 13, 2018 :
    Your phone is shaking or your hand? ;)
  5. F_Agas_J_Selas_hsLB
  6. Sunil Sriram
    Gingerbread Mar 13, 2018
    Sunil Sriram , Mar 13, 2018 :
    Yeah..! I agree... it's the same with me as well.. waiting for next update
  7. prajnay0
    Ice Cream Sandwich Mar 13, 2018
  8. Sunil Sriram
    Then which version your using now?
  9. prajnay0
  10. smith.pranjul
    Honeycomb Mar 13, 2018
    F_Agas_J_Selas_hsLB likes this.
  11. lblokendra
    Eclair Mar 14, 2018
  12. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Mar 14, 2018
  13. lblokendra
    Eclair Mar 14, 2018
    lblokendra , Mar 14, 2018 :
    sorry to say my hand is not shaking...it's camera...
    and after restarting the phone how it get clear photo...
  14. ArmataReloaded
    Jelly Bean Mar 14, 2018
    ArmataReloaded , Mar 14, 2018 :
    Sounds strongly like placebo-effect. Your hand was clearly shaking on your provided picture. Its not like the camera is spinning circles and you need to find the right second.
    Make a test yourself. Next time, if it seems like that it is shaking again, clean your lense - put your phone on a flat surface and try to capture a picture. Report back with the result
  15. F_Agas_J_Selas_hsLB
    Cupcake Mar 17, 2018
    F_Agas_J_Selas_hsLB , Mar 17, 2018 :
    please check this photo, it's not because the hand shake.... phone have some issue after the update.
    You can find the building is but curvy....it's an serious issue...
  16. ArmataReloaded
    Jelly Bean Mar 17, 2018
    ArmataReloaded , Mar 17, 2018 :
    Check the marked regions. Camera is trying to focus but it seems like that there is evaporated water or some kind of fluid inside your camera or on the lense. Check for both. I am convinced that this has nothing to do with the update. Was your phone exposed to any kind of water/rain/ tropical region?
  17. lblokendra
    Eclair Mar 18, 2018
    lblokendra , Mar 18, 2018 :
    what kind of excuses are provided....if u can't accept the fault... no need to explain
  18. Bouncer71
    OnePlus 7 Pro Sample Shot Photographer Community Expert Mar 18, 2018
    Bouncer71 , Mar 18, 2018 :
    this is motion blurr...
    you can clearly see the ghosting at the letters in the background...
    the camera sensor cannot move on it's own...
    ISO 800 and shutter speed 1/33 second...
    low light conditions + not holding the camera still...
    sorry to say, but that is a user fault...
  19. F_Agas_J_Selas_hsLB
    Cupcake Mar 18, 2018
    F_Agas_J_Selas_hsLB , Mar 18, 2018 :
    if so..then how I can capture clear photos as well...this doesn't come all the time but yes...it's an issue facing after the update... Of you provide fix then it's good but keep on argue that this is kind of fault from my side
  20. Bouncer71
    the shot of the building looks like a panorama shot gone wrong...
    l don't say it is...!
    but certainly looks like it...?
