2
Reboot Problem via OnePlus 6T
  1. Fabio Palumbo
    Froyo Feb 27, 2020
    vovowong and IbanezHartman like this.
  2. Mr.Steve
    Gingerbread Feb 27, 2020
    drl431 likes this.
  3. the_o2
    User of the Year 2018 Feb 27, 2020
    the_o2 , Feb 27, 2020 :
    Generally its app's problem, make sure all the apps are updated from Play Store.
    Caomhin, drl431 and Fabio Palumbo like this.
  4. Fabio Palumbo
    Froyo Feb 27, 2020
    Fabio Palumbo , via OnePlus 6T , Feb 27, 2020 :
    Yes, they are. I read that other people have the same issue
    IbanezHartman and the_o2 like this.
  5. the_o2
    Are you on beta version of Oxygen OS or those apps?
    Caomhin likes this.
  6. Fabio Palumbo
    Froyo Feb 27, 2020
    the_o2
    Are you on beta version of Oxygen OS or those apps?​
    I'm not on Beta. Anyway just a few seconds ago my phone rebooted again. It seems like an App Crash. 🙄
    IbanezHartman likes this.
  7. the_o2
    You better report it as a bug here
    https://forums.oneplus.com/feedback
  8. vovowong
    Gingerbread Mar 15, 2020
    Fabio Palumbo likes this.
  9. Caomhin
    Lollipop Mar 16, 2020
    Caomhin , via OnePlus 6T , Mar 16, 2020 :
    Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of Android. So you will need to backup your phone.
    After Backing up the phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button,
