136
Received my OP2 (24 hours) AMA!
  1. aakashjhaveri
    Lollipop Aug 26, 2015
    aakashjhaveri , Aug 26, 2015 :
    Exactly
    Is great
    Garyo1 likes this.
  2. tdark
    Gingerbread Aug 26, 2015
    tdark , Aug 26, 2015 :
    @aakashjhaveri
    Can you comment on the battery life? I received mine 1.5 days ago, I'm starting to worry that my battery might be defective. Still going through my tests, will update soon...
  3. aakashjhaveri
    Mine is good
    Easily lasts a day
    Check which apps consuming your battery
  4. tdark
    I'm doing a light-medium usage battery test today. So far, it doesn't look too good. The gap in the middle is when my phone rebooted for no reason while in my pocket. As you can see, android system has very high battery drain.
    I only played Leo's fortune for about 15 minutes in the morning. I've had no calls and have only used the phone for whatsapp and maybe 5-10 minutes of reading on Flipboard.
  5. aakashjhaveri
    For testing purposes
    I used my OP2 without a Sim for 10 days
    Battery life is good
    If i try, I might get almost 2 days of use
    Did you update your OP2?
    Also, today was my first switch off, but I think it happened due to my mistake
    And phone cold down within 5 minutes
    Garyo1 likes this.
  6. Garyo1
    Eclair Aug 26, 2015
    Garyo1 , Aug 26, 2015 :
    @tdark as per the images you hav got 2 hrs 35 min of screen on time and u still have 50 % battery.
    It seems to be fine. I m sure you will get more than 4 hr 35 min of SOT which is too good.
  7. ianeire
    Froyo Aug 26, 2015
    ianeire , Aug 26, 2015 :
    4-4.5 hours screen on time would be considered average I think, anything above that is very good. Gaming will always reduce that of course.
  8. Msns888
    Msns888 , Aug 26, 2015 :
    Ch
    cheers bro congrts
    Bro just one question does it really get hot to handle.
    I own opo getting op2 for my brother
  9. aakashjhaveri
    Warm, not hot
    Just lock it and don't use for 2-3 minutes, will be COLD again
    If you keep using even then, you might observe throttling after playing heavy 3D game for more than 80 minutes
    Msns888 likes this.
  10. aakashjhaveri
    Yes I agree
    rkmunjuluri likes this.
  11. Hardip Singh
    Froyo Aug 26, 2015
    Hardip Singh , Aug 26, 2015 :
    irritating process to buy :(
  12. tdark
    you're bound to get higher battery life without sim. Cell standby causes a significant drain.
    Yes, I updated it on the very first boot.
    I ended up getting 5 hours 20 minutes until the battery dropped to 1%.
    The last 45 minutes was me playing heavy games to finish off the last remaining charge before it was time to sleep. I admit, it's not AS bad as I initially thought, and the battery life is in fact acceptable, however it's still not extra-ordinary. However, there seems to be a lot of room for improvement. I'll post a detailed analysis tomorrow. I've found reasons to believe that the battery life could extend significantly with software updates.
    Garyo1 likes this.
  13. aakashjhaveri
    Lollipop Aug 27, 2015
    aakashjhaveri , Aug 27, 2015 :
    My battery life was bad initially
    Maybe it takes a few charge cycles
  14. Garyo1
    Eclair Aug 27, 2015
    Garyo1 , Aug 27, 2015 :
    @aakashjhaveri let your battery drain down to 0% 2 to 2 times a week, at least in the first month of purchase.
    That is my personal experience.
  15. Himanshu Duniwal
    Cupcake Aug 27, 2015
  16. Himanshu Duniwal
  17. sodhi93
    Donut Aug 27, 2015
  18. aakashjhaveri
    Yes
    Gets better each time
  19. aakashjhaveri
  20. aakashjhaveri
    Since I have got no more questions
    I end the testing phase, and use the phone as my normal daily phone
    Been an amazing 13 days
