2
Received OP cardboard and First Impressions!
  1. S1mwiz
    Gingerbread Jul 10, 2015
    S1mwiz , Jul 10, 2015 :
    Hold it the way I have shown in the picture and try decreasing and increasign that angle to see if it improves.
    #41
    BehnanAdam likes this.
  2. S1mwiz
  3. BehnanAdam
    BehnanAdam , Jul 10, 2015 :
    Thanks for your reply...
    it didn't work...I still see two of everything...with some headache...3 hours of trying
    thanks again...
    #43
  4. vchristophe
    Honeycomb Jul 10, 2015
    #44
    volteon likes this.
  5. S1mwiz
    Ohh, it might be due to the incorrect distance between the lenses. Try creating your own profile on Google's site and with different distances between the lenses and see if it helps. Also, I had this experience where I saw two impositions. When I tried and forced myself to focus on the objects, the images converged. Try that, it may be just the lapses in interpretation by brain and with some effort you may see it clearly?
    #45
  6. BehnanAdam
    #46
    S1mwiz likes this.
  7. S1mwiz
    Great, can you post all the parameters?
    #47
  8. BehnanAdam
    #48
    agoinfly likes this.
  9. S1mwiz
    Did you not alter the distortion coefficients? You would need to have lens calibration grid on our OPO inside the cardboard to judge it though.
    #49
  10. mcam435
    Donut Jul 10, 2015
    mcam435 , Jul 10, 2015 :
    This works much better than the one that OnePlus posted, at least for me. Thank you!
    #50
  11. DeRijckeYordi
    DeRijckeYordi , Jul 10, 2015 :
    I absolutely disagree with the higher DPI, i tried myself and everything looked way sharper when i switched my OPO to 320DPI!
    #51
  12. visdarius
    Froyo Jul 10, 2015
    #52
  13. kristof1985
    Cupcake Jul 10, 2015
    #53
  14. Restorer
    Donut Jul 10, 2015
    Restorer , Jul 10, 2015 :
    Mine arrived this morning too. Glad it came in one piece - wasn't looking forward to all that folding. Selector works differently than on the last one I saw. That used a magnet and some kind of NFC jiggery pokery - this seems just a simple rocker that touches the screen.
    #54
  15. Arsh21
    Arsh21 , Jul 10, 2015 :
    Great. There you go
    #55
  16. jeffers
    jeffers , Jul 10, 2015 :
    Definitely works better than the main one.
    #56
  17. chipples
    chipples , Jul 10, 2015 :
    ^^ Wow, that is significantly better than the main one, which is unusable for me. Makes me wonder what the hell they are smoking at OnePlus HQ.
    #57
  18. carlosfilippsen
    Ice Cream Sandwich Jul 10, 2015
    #58
  19. BlindCinema
    BlindCinema , Jul 10, 2015 :
    Awesome! Mine got sent yesterday. Maybe arrives tomorrow or next monday. Anyway, I'll see If I can make some mods so some of the cardboard edges or corners don't "fray" or come apart. Thinking cap is on!
    #59
  20. williamhaven
    Ice Cream Sandwich Jul 23, 2015
    williamhaven , Jul 23, 2015 :
    So the the side volume button keeps being pressed most of the time because of the strength cardboard is applying. Isn't anyone else having this issue?
    I'm thinking on cutting a hole where the button are...
    Any other Mod suggestions out there?
    #60
