Recommend Me Best Charging Dock for OnePlus 6?
  1. iOStoAndroid
    Gingerbread Jul 1, 2018
    iOStoAndroid , Jul 1, 2018 :
    I figured... why would I need wireless charging if I can just dock the phone overnight!
    I am looking for something that can support the Dash charge (20w). A lot of ones I saw got to 2A at most... But I do not want to lose speed with the dock. Are there ones claiming max speed at 2A, but in reality goes up to 4A with the dash charger?
    Anyone have good recommendation? Thank you for your reply in advance!
  2. pa5t1s
    User of the Year 2014 Jul 1, 2018
    pa5t1s , Jul 1, 2018 :
    I'm not sure you will find any supporting Dash Charging (Rapid Charge)
    cozzmat likes this.
  3. soROCKin88
    soROCKin88 , Jul 1, 2018 :
    unfortunately I think you are right... I think you have to hope that OP does one dock with dash
    pa5t1s likes this.
  4. GuitarBart
    Jelly Bean Jul 1, 2018
    GuitarBart , Jul 1, 2018 :
    Wouldn't it be easier to build a DIY dock for the time being with a dash cable? I don't think there are any yet...
    soROCKin88 likes this.
  5. pa5t1s
    Yep, but that could happen, likely... Gotta ask @Carl :)
  6. iOStoAndroid
    Darn... Yea the highest I found got to 2.4A but in reality probably supports 2A flat.. Would have to compensate a lot in terms of charging speed for... perceived convenience (?)
    It's $2.50 including shipping (!) so I am thinking of getting just to try and see if docks are convenient for me to warrant further research..
  7. soROCKin88
    let us know
  8. iOStoAndroid
    Will definitely let you know.. Just wait 3~4 weeks.. Got it off of Ali and coming from China :)
  9. soROCKin88
    np!
  10. glenn51
    glenn51 , Jul 1, 2018 :
    I got one from amazon £6.45 it did not work Sent it back for a refund the seller said it was for oneplus 6 it did have c-type USB tryed it without dash charger still did not work.
  11. benulin1
    Honeycomb Jul 1, 2018
    benulin1 , Jul 1, 2018 :
    There are some docks where you can use your own dash charge cable and power brick.
  12. thetonyclifton
    Froyo Jul 1, 2018
    thetonyclifton , Jul 1, 2018 :
    If you are docking it overnight does it really need to be dash charging? Getting a OP6 has completely changed how I charge my phone. I used to charge it overnight but not anymore. I just throw it on the dash charger in the morning while I eat breakfast and get ready, sometimes I top up to 100% when I get to work using a regular USB-C charger (from my old Pixel XL). My phone rarely spends more than 45-75mins on a charger anymore.
    Extreme_0ne and SomeBob like this.
