Sound recorder Voice notes in WhatsApp have low volume
  1. wtrn06
    Cupcake Apr 2, 2021
    wtrn06 , Apr 2, 2021 :
    When recording (my side, Oneplus6) a voice note in the app WhatsApp, this voice note has a low recording volume. The voice note sounds like i'm recording the message from a long distance.
    My guess would be that the 'wrong' microphone is used to record this type of voice messages in WhatsApp.
    Looking around the internet, it seems i'm not the only one having this issue.
    Using the build in sounds recorder app, the results are the same normal
    Device: Oneplus 6
    Software: 10.3.9
    Factory reset has been done multiple times without result.
  2. Overzee
    The Showcase Reviewer Apr 2, 2021
    Overzee , Apr 2, 2021 :
    Did you check the bottom of the phone for dust and stuff that builds up in the small holes?
  3. Overzee
    Looks like that's clean, missed this line apparently. Nevertheless a check for dust is easily done.
  4. M1579365931064
    Cupcake Apr 2, 2021
  5. sumitMZ007
    Jelly Bean Apr 4, 2021
