5
[RECOVERY] Hybrid Recovery v3.x
  1. whyorean
    Gingerbread Jun 14, 2016
    whyorean , Jun 14, 2016 :
    Screenshot_2016-06-07-04-57-55.png Here you go with Hybrid Recovery v3.x for OnePlus X
    #One Recovery for All
    1. Oxygen OS
    2. Hydrogen OS
    3. CM 13 Official
    5. Paranoid ROM Official
    Flash this Recovery using your current recovery or via fastboot, and Enjoy!
    Download: Hybrid Recovery v3.3
    Code:
    1. Hybrid UI, Simple and Beautiful.
    2. Optimized Animation and Speed
    3. Added SysLog and SysInfo in Advance Section.
    4. Added Missing Partitions
    5. OTG Support
    6. Added ViewLog Option in Install Section
    Screenshot:
    Screenshot_2016-06-07-04-57-55.png Screenshot_2016-06-07-04-58-19.png Screenshot_2016-06-07-04-58-30.png
  2. Kéno40
    Jelly Bean Jun 14, 2016
  3. whyorean
    Kéno40 likes this.
  4. Kéno40
    Kéno40 , Jun 14, 2016 :
    Ahah thanks !
    Could it come with OOS 3, please ?
    Note : I'm kidding. Just tell it because it's a sensible subject here :)
  5. whyorean
    huhh..! :cool::cool:
  6. Bounze
    Honeycomb Jun 14, 2016
    Bounze , Jun 14, 2016 :
    seems to be working :) I really like the theme and it shows me my backups made in TWRP so that works fine, gonna try to update cm13 now see if that works.
  7. Bounze
    wasn't it supposed to update oxygen without replacing it and returning to stock recovery?
  8. sunny33438
    Froyo Jun 14, 2016
  9. sunny33438
    Froyo Jun 15, 2016
  10. RJ Murdok
    Ice Cream Sandwich Jun 15, 2016
  11. locxFIN
    KitKat Jun 15, 2016
    locxFIN , Jun 15, 2016 :
    No, the name Hybrid came from when official TWRP didn't work with OOS 3.0 on OP2, they had to make a custom version of it. This one worked with both OOS 3.0 and 2.2.1, hence the Hybrid.
    Yes, custom recovery doesn't break OTA, only rooting does.
  12. Bounze
    Honeycomb Jun 15, 2016
    Bounze , Jun 15, 2016 :
    rooting doesn't break it if you use flashfire by chainfire (maker of SuperSU)
  13. locxFIN
    KitKat Jun 15, 2016
    Still a workaround, most people just want to click on install.
  14. twentyfourinc
    Gingerbread Jun 16, 2016
  15. dhairyarc1
    Ice Cream Sandwich Aug 29, 2016
  16. Patman75
    KitKat Aug 29, 2016
  17. Филатов Павел
    Cupcake Aug 30, 2016
    Филатов Павел , Aug 30, 2016 :
    Didn't work for me. Flashed it via Flashify and on booting into recovery I get bootloop. Restored stock one through the same Flashify and it is ok.
  18. Kéno40
    Jelly Bean Aug 30, 2016
    Kéno40 , Aug 30, 2016 :
    You mean on OOS CM 3.1?
  19. Grobnev
    Grobnev , Aug 30, 2016 :
    I also tried flashing this on OOS 3.1 (community build) - didn't work. Getting the same error: (remote: dtb not found). Flashed it and then tried booting it. Flash seems succesful, booting gives the error.
    And sorry if I'm completely misunderstanding something, but the name indicates it will support OOS 3.1 :)
  20. Филатов Павел
