Red tint issue. via OnePlus 7T
  1. asifwanderlust
    Gingerbread May 30, 2021
    asifwanderlust , via OnePlus 7T , May 30, 2021 :
    Hello folks,
    "Does anyone face the same issue?"
    I experience red tint issue in my OP 7T device. At the time of fingerprint unlock at lower brightness red tint appears and at lower brightness during normal use display tint changes occassionally.
    I've 2 devices purchased on same time. I've noticed it about 7-8 months ago in one device and noticed just now in nd device.
    Kindly check the images and help me the way you can.
  2. #2
  3. Steinchan
    Donut Jun 24, 2021
    asifwanderlust likes this.
  4. KluGe
    Lollipop Jun 24, 2021
    KluGe , Jun 24, 2021 :
    Yes, there are some.
    And there is an easy way to turn this red mode off. :)
    You just have to use Search to find how to do so ... ;)
    Auristic likes this.
  5. asifwanderlust
    Gingerbread Jun 24, 2021
    asifwanderlust , via OnePlus 7T , Jun 24, 2021 :
    Unfortunately there is mo solution so far even service center denied to solve this issue.
  6. asifwanderlust
  7. Helder_DAlmeida
    Marshmallow Jun 24, 2021
    Bobbie63 likes this.
  8. asifwanderlust
    Gingerbread Jun 25, 2021
    asifwanderlust , via OnePlus 7T , Jun 25, 2021 :
    I've visited service center but they failed to solve isse.
    Helder_DAlmeida likes this.
  9. Helder_DAlmeida
    Marshmallow Jun 25, 2021
  10. asifwanderlust
    First of all they kept for 10 days and afterwards said that's common in OnePlus 7T and can't be solved.
    sritejkoduru and Helder_DAlmeida like this.
  11. Helder_DAlmeida
    Helder_DAlmeida , via OnePlus 7T , Jun 25, 2021 :
    It's common?! What?! It's a shame such a bad service center...
    Bobbie63 and asifwanderlust like this.
  12. asifwanderlust
  13. beatitjust
    Eclair Jun 30, 2021
  14. #14
  15. asifwanderlust
    Gingerbread Jun 30, 2021
  16. AlwaysOneplus
  17. Does!Compute
    KitKat Jun 30, 2021
    Does!Compute , Jun 30, 2021 :
    Did you try booting into Safe mode to see if the issue can be replicated there? That will atleast make it clear on whether the OS is causing the issue, or a third party app.
    Secondly, does it only occur at a very specific brightness setting? (If yes, then the issue might be due to the hardware, particularly due to mis-calibrated greyscale).
    Third, does it only occur on the lockscreen?
  18. beatitjust
    Eclair Jun 30, 2021
  19. Bobbie63
    Marshmallow Jun 30, 2021
    Bobbie63 , Jun 30, 2021 :
    They sure have some nerve to give you this answer, especially in writing. While they at it talking about quality, this once again shows the quality of the OnePlus support.
  20. asifwanderlust
    Gingerbread Jul 1, 2021
    asifwanderlust , via OnePlus 7T , Jul 1, 2021 :
    Everything tired and red tint appears when it comes low brightness and fingerprint sensor.
