Refresh rate issue. Constant 120 hz via OnePlus 9 Pro
  1. Techbizz
    Gingerbread Oct 23, 2021
    Techbizz , via OnePlus 9 Pro , Oct 23, 2021 :
    See I have spent almost minimum 4-5 mins on each screen and just see it stays constant 120 hz on these screens. The main reason your battery is draining faster is because oneplus has not optimized screen refresh rate.
    Only time it goes from 120 to 60hz is when i open keyboard for typing.
    This is why oneplus 9 pro fails with battery expectations.
  2. pa1.
    Ice Cream Sandwich Oct 23, 2021
    pa1. , via OnePlus 7T , Oct 23, 2021 :
    Yes the issue has been there since Android 10 and not fixed till date, same is the issue with other phone like 7 pro , 7T and now 9 . I have talked about this issue since 6 months ago still not fixed.
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 23, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Oct 23, 2021 :
    The developer setting option is not capable of showing the true refresh rate of the dynamic refresh rate feature. It shows only the mode it is using.
    If you to control 60 or 120 beyond the automatic options you can use the app AutoHz.
    Artemus and Caomhin like this.
  4. pa1.
    Ice Cream Sandwich Oct 24, 2021
    pa1. , via OnePlus 7T , Oct 24, 2021 :
    I disagree with this fact you stated. There is a color shit you can see if you look clearly. In my 7T in 90 Hz I can see the tint issue but not in 60 Hz , while using the 90 Hz when I use keyboard the tint issue goes away and refresh rate is shown 60 . Your might be talking about LTPO technology's dynamic refresh rate which is not the argument about for this case since 7T doesn't have dynamic refresh rate . This is a software issue, the best option is to report in feedback section.
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 24, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Oct 24, 2021 :
    I responded to the tread owner (but could not quote the post due to using the app). That user is using a 9 Pro with LTPO. In that case 120 Hz is not necessarily always 120 Hz even if the monitor shows it (it only shows the mode it is in, not the real Hz).
    On a 9 Pro the 60 Hz mode may still be used in some situations. But in some cases 120 Hz could actually be more efficient since it can go below 60 Hz.
