Refresh rate problems with Android 11 update
  1. kotalkar
    Donut Apr 20, 2021
    kotalkar , Apr 20, 2021 :
    Hi. I have OnePlus 7 pro and just recieved Android 11 version with Oxygen OS 11. Design is great, but the thing is, that using this phone now is just terrible. Here are some things;
    -scrooling feels (and probably is) like 20hz, not 90hz
    -battery is draining fast
    - gallery working very bad
    - some other buggs
    Does somebody know when will the update come to fix this? Also, updates for 7 pro end on 14th May, so there is not so much time left...
    There has to be an update soon, because living with this is a "no go"...i wont buy any more OnePlus phones if this is not fixed now...
    F_Prasanth_P_YkTN likes this.
  2. #2
  3. kotalkar
    Donut Apr 20, 2021
    But I talked to one of their clients and they said update will come soon...
    So you are telling me that im stuck with this slow refresh rate...i mean man, I cant even scrool properly..
  4. #4
  5. kotalkar
    Donut Apr 20, 2021
    Hahaha Im not quite sure about that. I talked to more of them ( on contact us) and every one said different...complete crap....sory #oneplus but you should fix this main things on 7 series
  6. Sandeep Poddar
    Ice Cream Sandwich Apr 21, 2021
    Sandeep Poddar , via OnePlus 7T , Apr 21, 2021 :
    Try clearing the cache from recovery and it will probably be fine after few hours. I myself had experienced this when upgraded my OP7T from OS10 to OS11. Most of the things will be fine after a charge cycle.
  7. kotalkar
    Donut Apr 21, 2021
    kotalkar , Apr 21, 2021 :
    Hi, yes, I cleared cache and everything is the same...😕😕
  8. PK1233
    Eclair Apr 21, 2021
    PK1233 , via OnePlus 7T , Apr 21, 2021 :
    Bro is lift to wake up and doble tap to wake working perfectly..?
    Coz multiple users and multiple threads have been reported for that issue.
    And yes apart from that I couldn't notice any major issues with the net hotfix
  9. kotalkar
    Donut Apr 21, 2021
    Yes, double tap and lift to wake up is working fine but the only two things that are the main problem are as I said;
    - scrolling is so freaking slow
    -gallery not working properly
    - battery drain is not so much of a problem anymore
    PK1233 likes this.
  10. ghostofcain
    Marshmallow Apr 21, 2021
    ghostofcain , Apr 21, 2021 :
    I wouldn't worry about your scrooling. Although a spell check wouldn't go amiss.
    Dsquared1955 likes this.
  11. Sam197
  12. kotalkar
    Donut Apr 21, 2021
    Haha what? I really care about speed, so i need that 90hz, i cant use my phone if it is so slow..
  13. kotalkar
    Donut Apr 21, 2021
    I did this:
    - Power off your device.
    - Press the power key + volume down
    for a few seconds.
    - Select English.
    Tap on Wipe data and cache.
    - Tap on Wipe data and cache again.
    - Tap on Yes to confirm data and cache wipe.
    - Wait for the wipe process to
    complete.
    - Reboot the phone.
    And its the same..
