Regarding motion graphics smoothing and hyper motion smoothing via OnePlus 8 Pro
  1. Deepak Mittu
    Cupcake May 16, 2021
    Deepak Mittu , via OnePlus 8 Pro , May 16, 2021 :
    Motion graphics smoothing and hyper motion smoothing aren't getting started most of the time even when the screen resolution is set at FHD+. This is happening almost every time .so please look into this ASAP
  2. wordlife2010
  3. #3
  4. wordlife2010
    Cupcake May 18, 2021
    wordlife2010 , via OnePlus 8 Pro , May 18, 2021 :
    Go to the Google store
    Search for YouTube
    You will find uninstall press it and it will be back to the previous version
    Than it will work
    Give it a try
  5. Deepak Mittu
  6. Tokolozi
    Most Original Avatar May 18, 2021
    Tokolozi , May 18, 2021 :
    Not all apps support motion smoothing, make sure these are supported first.
  7. Deepak Mittu
    Cupcake May 20, 2021
