Battery/Charging Replacement charger and usb adapter
  1. xulos
    Eclair Aug 9, 2018
  2. xulos
    Eclair Sep 1, 2018
  3. Rakesh_Kumar_T
    Jelly Bean Sep 1, 2018
    Rakesh_Kumar_T , Sep 1, 2018 :
    Samsung produces very good quality products ,I never felt the use of such an accessory but if I were to pick one, I would pick one of the best ones in the market and Samsung is one among them ,
  4. Deactivated User
    Sep 1, 2018
  5. DenyDarko
    Honeycomb Sep 1, 2018
    DenyDarko , Sep 1, 2018 :
    As long as you don't buy a Chinese OEM for 1$ but a branded one from a respectable manufacturer, you'll be fine.
    They all do the same thing, delivering power through USB.
    Just make sure it's at least 1A so it'll charge your battery a bit fast.
  6. DrAakash
    DrAakash , Sep 1, 2018 :
    Use any good qc 3.0 charger and cable, the charging speed isn't that much slower than dash charging.
  7. xulos
    Eclair Sep 2, 2018
    xulos , Sep 2, 2018 :
    didnt they say its not recommended to use quickcharge equipment on oneplus cellphones?
  8. hahaha2223
    Jelly Bean Sep 2, 2018
    hahaha2223 , Sep 2, 2018 :
    Technically it would be fine.
    QC will just push 5v on whatever amp is max in that situation
