2
Replacement HIGH-SPEED USB Cable
  1. xtopheralan81
    Gingerbread Oct 17, 2014
    xtopheralan81 , Oct 17, 2014 :
    I've now purchased FOUR different cables (flat, braided, etc) that do NOT charge the OnePlus at the same speed as the OEM cable. They're all 1/4 the speed as verified in a few different charging widgets. As soon as I plug in the OEM cable it charges at full speed. Here is the last one I bought which claims to be AWG28 and looks like the OnePlus cable, but STILL doesn't charge as fast (1/4th again).
    http://www.ebay.com/itm/17143391922...49&var=470465819503&ssPageName=STRK:MEBIDX:IT
    Any idea on cables that DO charge at the full speed? I've bought the highest AWG I could find and they still aren't charging at full speed. This is using the OEM wall charger.
    ronoldo and deepthought42 like this.
  2. gusuraman
    Community Veteran Oct 17, 2014
    maken15, deepthought42 and tarikida like this.
  3. sbtkd85
    Honeycomb Oct 17, 2014
    sbtkd85 , Oct 17, 2014 :
    Make sure they are rated to carry 2.1A across the cable before buying. I'd go for a better cable, below 28AWG like @gusuraman suggested.
  4. jizang
    Lollipop Oct 17, 2014
    jizang , Oct 17, 2014 :
    OP does sell their usb cables on their china site, maybe they will sell it worldwide in the future?
    deepthought42 likes this.
  5. gusuraman
    gusuraman , Oct 17, 2014 :
    It still too short
    caldrich and deepthought42 like this.
  6. Chris Haidze
  7. xtopheralan81
  8. gusuraman
    Mistery
  9. xtopheralan81
    I'm looking for 5foot minimum. Any recommendations? The KOPI on Amazon is only around 3ft or I'd get it :(
  10. the_garz
    Froyo Oct 23, 2014
    the_garz , Oct 23, 2014 :
    http://www.ebay.com/itm/181565990803
    This guy makes them himself. Specifically designed to pull the highest AMPs your phone can handle and your charger can put out. It's a charging only cable, as he removes the data portion to enable this functionality. I just purchased one based on his screenshots of his nexus charge times. Pretty expensive for a 6 foot. I'll update when I receive it and use it.
  11. Suneth
    Honeycomb Oct 23, 2014
    Suneth , Oct 23, 2014 :
    Try the Nilkin Cable. i'm using it to charge my OPO and it's as fast as original cable. i can't give you the link since Ali**** is banned. but you can search and find it.
    Ray130021 and ronoldo like this.
  12. BorgHead
    Gingerbread Oct 23, 2014
    ronoldo likes this.
  13. kopi-support
    Donut Nov 17, 2014
    kopi-support , Nov 17, 2014 :
    Thanks you for all your kind words. Our Kopi 20AWG 1M normal has sold out on Amazon.
    We have our new 20AWG reversible plug on Amazon now to replace the normal cable. It is 6.99USD on Amazon.
    http://www.amazon.com/gp/product/B00OYQ4D4U
    You can still find the normal (non-reversible) 20AWG cable on Newegg.
    http://www.newegg.com/Product/Product.aspx?Item=9SIA4AR1WR1502&cm_re=kopi-_-9SIA4AR1WR1502-_-Product
    Our 2M is also available now on Amazon.
    http://www.amazon.com/2-1A-Micro-Sy...e=UTF8&qid=1416198985&sr=8-1&keywords=kopi 2M
    Best Regards,
    Sam
    Kopi - general@kopi-d.com
    moonspeak, DQuietOne and ronoldo like this.
  14. saminpgh
    KitKat Nov 17, 2014
    saminpgh , Nov 17, 2014 :
    Your cables are the fastest charging ones I have used. Do you have any longer than 3ft?
  15. kopi-support
    Donut Nov 17, 2014
  16. jthe111
    Jelly Bean Nov 17, 2014
    jthe111 , Nov 17, 2014 :
    Im sorry I feel like a nub. What in the hell is the difference between a reversible and a non-reversible cable?
    maken15 likes this.
  17. leekokkheng
  18. maken15
    Gingerbread Nov 18, 2014
    maken15 , Nov 18, 2014 :
    ^i would like to know too. does anyone know? and is it okay/safe to use a wall charger that has an output of 5.2~2.4amps on the opo? thanks
  19. maken15
    did you get the cable yet? and how is it?
  20. kopi-support
    Donut Nov 19, 2014
    kopi-support , Nov 19, 2014 :
    The larger usb end can be plugged into standard USB slot facing up or down. The micro end is still the same.
    Sam
    4nlimited3dition and moonspeak like this.
