Replacement of OnePlus 6 battery. via OnePlus 6
  1. E1578293415195
    Cupcake Aug 18, 2020
    E1578293415195 , via OnePlus 6 , Aug 18, 2020 :
    I am using oneplus 6 special edition silk white!
    I want to change its battery! Did anyone changed their battery of op6?
    Plz mentioned the price if anyone had changed it!
    And i am little scared for the replacement! 🥺🥺 Coz it's white one! They will stick the back panel as new one? N? 🥺🥺
  2. drl431
    Nougat Aug 18, 2020
    drl431 , Aug 18, 2020 :
    For pricing, go to the OnePlus website, support tab, then repair pricing. The back cover would only be replaced if it was broken when they received it.
  3. bindobond
    Eclair Aug 18, 2020
    bindobond , Aug 18, 2020 :
    recently I changed my battery from service center but it's giving the same back up. I don't know how to check weather battery is changed or not.
    battery cost me 600 rs
    E1578293415195 likes this.
  4. P1542079842235
    Donut Aug 19, 2020
    P1542079842235 , Aug 19, 2020 :
    download a OnePlus diagnostic tool and check the battery health
  5. bindobond
    Eclair Aug 22, 2020
    bindobond , Aug 22, 2020 :
    diagnostic app already installed . before changing the battery it's was showing good now also showing the same . but the backup is same as compared to the previous battery.
    neither it's taking less time to charge in rapid mode.
    so how can I check if the battery is changed.
  6. Caomhin
    Marshmallow Aug 22, 2020
    Caomhin , via OnePlus 6T , Aug 22, 2020 :
    What was the actual previous battery health showing as a percentage compared to the new one.
    There is no way to see if a battery is changed, batteries give generic information such as in the CPU-Z image below.
  7. bindobond
    Eclair Aug 22, 2020
    Caomhin
    in old battery health was good and in new one is also health is good . I changrd the battery because the backup was not good and after replacing , the backup is same . so just wanted to know weather the battery was replaced or not , how can I check. if then it's new one or not
  8. Caomhin
    You would need to use the same app to measure Battery health, example old battery 70%, new battery 100%, then you can see its a new battery. But if the percentages are the about same for old and new, then maybe its an older battery.
    Check the actual percentage health of the new battery with the OnePlus Diagnostic tool. See if its close to 100%, it may show 97%, 98% but that's close enough as the battery health indicators work to a tolerance of a couple of percentage points either way.
    Download OnePlus Diagnostic tool.
    https://www.apkmirror.com/apk/oneplus-ltd/oneplus-diagnostic/
    This my current battery health on an OP6T using this tool
    drl431 likes this.
  9. bindobond
    Eclair Aug 22, 2020
    I already checked by using pubg that's why I am asking thing questions. [e]1f62d[/e]
  10. Caomhin
    And what is the result of the Diagnostic tool with your new battery?
  11. bindobond
    Eclair Aug 22, 2020
    good
  12. Caomhin
  13. bindobond
    Eclair Aug 22, 2020
  14. bindobond
    Eclair Aug 22, 2020
  15. Caomhin
    bindobond
    66 percentage​
    Is that the health percentage, or the use percentage.
    Is this the new battery, if so then bring it back, it should be nearer 100% health.
  16. bindobond
    Eclair Aug 22, 2020
    battery heath and charge shwoing same
  17. Praty_28
    KitKat Aug 22, 2020
  18. Caomhin
    bindobond
    That's not the Diagnostic Tool. That's the battery usage percentage. Not the Battery Health.
    Have a look at mine above I posted earlier, that's what it should look like in the layout.
    Check the image below, where it says Battery Capacity and on mine It says 3700Mah.
    Click on the Red text where it says Battery Status.
    That will show your battery health.
    drl431 likes this.
  19. bindobond
    Eclair Aug 22, 2020
    getting warning massage
  20. bindobond
    Eclair Aug 22, 2020
