2
{REQ} CM12S Theme
  1. svw
    Froyo May 10, 2015
    svw , May 10, 2015 :
    I tried porting it, but unfortunately it doesn't seem to work. But maybe it works on your OPO, since I tried it on a Galaxy Tab.
    This is the stacktrace I got, maybe someone can help me with that:
    Code:
    E/AndroidRuntime(11595): java.lang.NullPointerException: Attempt to invoke interface method 'boolean android.database.Cursor.moveToPosition(int)' on a null object reference
    E/AndroidRuntime(11595):     at com.cyngn.theme.chooser.ChooserActivity.populateCurrentTheme(ChooserActivity.java:767)
    E/AndroidRuntime(11595):     at com.cyngn.theme.chooser.ChooserActivity.onLoadFinished(ChooserActivity.java:846)
    E/AndroidRuntime(11595):     at com.cyngn.theme.chooser.ChooserActivity.onLoadFinished(ChooserActivity.java:69)
    E/AndroidRuntime(11595):     at android.support.v4.app.LoaderManagerImpl$LoaderInfo.callOnLoadFinished(LoaderManager.java:427)
    E/AndroidRuntime(11595):     at android.support.v4.app.LoaderManagerImpl$LoaderInfo.onLoadComplete(LoaderManager.java:395)
    E/AndroidRuntime(11595):     at android.support.v4.content.Loader.deliverResult(Loader.java:104)
    E/AndroidRuntime(11595):     at android.support.v4.content.CursorLoader.deliverResult(CursorLoader.java:73)
    E/AndroidRuntime(11595):     at android.support.v4.content.CursorLoader.deliverResult(CursorLoader.java:35)
    E/AndroidRuntime(11595):     at android.support.v4.content.AsyncTaskLoader.dispatchOnLoadComplete(AsyncTaskLoader.java:223)
    E/AndroidRuntime(11595):     at android.support.v4.content.AsyncTaskLoader$LoadTask.onPostExecute(AsyncTaskLoader.java:61)
    E/AndroidRuntime(11595):     at android.support.v4.content.ModernAsyncTask.finish(ModernAsyncTask.java:461)
    E/AndroidRuntime(11595):     at android.support.v4.content.ModernAsyncTask.access$500(ModernAsyncTask.java:47)
    E/AndroidRuntime(11595):     at android.support.v4.content.ModernAsyncTask$InternalHandler.handleMessage(ModernAsyncTask.java:474)
    E/AndroidRuntime(11595):     at android.os.Handler.dispatchMessage(Handler.java:102)
    E/AndroidRuntime(11595):     at android.os.Looper.loop(Looper.java:135)
    E/AndroidRuntime(11595):     at android.app.ActivityThread.main(ActivityThread.java:5256)
    E/AndroidRuntime(11595):     at java.lang.reflect.Method.invoke(Native Method)
    E/AndroidRuntime(11595):     at java.lang.reflect.Method.invoke(Method.java:372)
    E/AndroidRuntime(11595):     at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:898)
    E/AndroidRuntime(11595):     at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:693)
    The ThemeChooser also complains about not finding a ThemesProvider.
    These are the steps I did:
    1. Extracted ThemeChooser.apk and ThemesProvider.apk from my OPO
    2. Installed ThemeChooser.apk and ThemesProvider.apk as a system app (on the other device)
    3. Rebooted the device
    4. Tried to open the app
    Maybe you'll get it working on your device ;)
    #41
  2. Johnwilliamcalhoun
    Eclair May 10, 2015
    #42
  3. noam9509
    Cupcake Jul 9, 2015
    noam9509 , Jul 9, 2015 :
    Hey I realy like your theme is there anyway you can accept me thanks +noam dadon
    #43
    Adrián Daraš likes this.
  4. Adrián Daraš
    Ice Cream Sandwich Jul 9, 2015
    Adrián Daraš , Jul 9, 2015 :
    I have accepted all people now.
    #44
