OxygenOS Reset battery stats?!?
  1. lmerega
    Honeycomb Dec 8, 2016
    lmerega , Dec 8, 2016 :
    Hi all, I saw my battery stats are incremental... Now I have 6 hours screen on without having still removed it from the charger.
    How can I reset the stats like in every android device?
    NOTE: I do not use DASH charger but a normal one.
    Thx
    .luca
  2. lmerega
    Ok, after charging it with original battery charger and cable, it resets stats.
    This evening I'll try with the original cable, but an alternative charger.
    I'll let you know.
  3. Iain18
    Cupcake Dec 9, 2016
    Iain18 , Dec 9, 2016 :
    6 hours thats impressive. i've only had my 3t for 5 days and it barely reaches 5hours. Any tips on how you got 6hours>?
  4. masi0
    Gingerbread Dec 9, 2016
  5. lmerega
    Honeycomb Dec 9, 2016
    Best Answer
    lmerega , Dec 9, 2016 :
    It was a fake because of the cable with the charger.
    This night I used a generic wall charger with original cable... Battery stats reset.
    It is a cable problem.
