[Resolved] File Manager Issue
  1. aledesi
    Gingerbread Sep 7, 2014
    aledesi , Sep 7, 2014 :
    Does anyone know why it's not possible to move files from a folder to another one using the CM File Manager? Whenever I try I get the following error message: "operation not allowed in the current folder" (or something similar, I have it set in Italian).
  2. Hanson Lee
    Marshmallow Sep 7, 2014
    aalsebaie and sp99 like this.
  3. gaster
    Moderator Moderator Sep 7, 2014
    gaster , Sep 7, 2014 :
    If you are using the classic file manager with this blue icon and this white circle, just go to the folder that you want. Then check the files or folders that you want by left of it in this tiny empty box and then go normally by using the back key or what else to the folder that you want and press the menu button of the file manager(this with the little dots) and select Copy Selection e.t.c. or Move Selection e.t.c
    firewire2035 likes this.
  4. oneeyedhobbit
    oneeyedhobbit , Sep 7, 2014 :
    What folder are you in? Many of the folders just inside of '/' (the root) are read-only unless you have SU permissions (i.e. rooted).
  5. aledesi
    Gingerbread Sep 8, 2014
    aledesi , Sep 8, 2014 :
    That method works, thank you! Not exactly the most intuitive and user friendly File Manager :p
    gaster likes this.
  6. gigs
    Ice Cream Sandwich Sep 8, 2014
  7. Big Ben
    Jelly Bean Sep 8, 2014
    Big Ben , Sep 8, 2014 :
    rooted?
  8. Aaahh
    Marshmallow Sep 8, 2014
  9. gaster
    Moderator Moderator Sep 8, 2014
    gaster , Sep 8, 2014 :
    You're welcome m8. If you work a bit with it you will understand that this file manager is the fastest on the transfering ways. That's i believe and that's how it works ;)
  10. stOk3d
    Eclair Oct 7, 2014
    stOk3d , Oct 7, 2014 :
    D file manager had gone missing after the OTA update... Any one have a clue what happened? Don't want to download an app. Bummer...
  11. pch288
    Cupcake Oct 26, 2014
    pch288 , Oct 26, 2014 :
    That method doesn't work all the time. I have "The file or folder" not found error.
