Restrict Background Data for App
  1. Narenso
    Froyo Jul 3, 2016
    Narenso , Jul 3, 2016 :
    Thanks for the solution ..
  2. F_Aarash_Wafah_SQVl
    Cupcake Jul 4, 2016
  3. manedark
    Gingerbread Jul 10, 2016
  4. shivtejjagtap
    Cupcake Jul 31, 2016
    shivtejjagtap , Jul 31, 2016 :
    For your 3 question.
    I have tried it on Google play. I restricted the data and disabled the second sim. After that Aslo I was getting the notification that background data is restricted. So it is applicable after you disabled one sim.
  5. shivtejjagtap
    Ye
    Yes it works. And oneplus must look into it.
  6. lipe123
    Froyo Sep 2, 2016
    lipe123 , Sep 2, 2016 :
    good catch I still had a sim in from another country that's totally useless atm and sure enough as soon as i enabled it the settings was avail.
    +1 for bug fix please
  7. HegdeVilas3585
    Cupcake Dec 17, 2016
    HegdeVilas3585 , Dec 17, 2016 :
    This is a big bug in the software. Data usage view doesn't show app-wise data usage details too. When will it be solved?
  8. rohit.s619
    Cupcake Dec 18, 2016
  9. hirakjsaha
    Froyo Jan 13, 2017
    hirakjsaha , Jan 13, 2017 :
    how to restrict background data on cellular network ?... without going to each and every app and restricting it one by one.
  10. saqlainsyed007
    Cupcake Apr 4, 2017
    saqlainsyed007 , Apr 4, 2017 :
    I am using OOS 3.5.6 and this worked for me
