resurection rom and xposed [HELP]
  1. frankiecortina
    Ice Cream Sandwich May 27, 2015
    frankiecortina , May 27, 2015 :
    so i recently flashed resurrection remix. a must have for me is to be able to have xposed. why cant i flash the xposed framework ? is the framework not compatible with some ROMS or am i doing something wrong ? can anyone else try to flash xposed with resurrection and let me know how it goes ? i like the ROM but xposed is a must have for me... this has happened on like three other ROMS that i have tried
  2. frankiecortina
  3. camohan
    Marshmallow Moderator May 27, 2015
  4. roshan.india
    roshan.india , May 27, 2015 :
    the official alpha is not yet compatible with 5.1 build roms... thrs a Super alpha available, but not ALL mods work in it..and if u install an uncompatible mod in it, ull get a bootloop...so my advice... if u REALLY want xposed THAT much...stay in a 5.0.2 rom (like COS12, exodus, Oxygen, etc)
    dsmonteiro likes this.
  5. SparkkIt
    Honeycomb May 27, 2015
    SparkkIt , May 27, 2015 :
    I second this advice. Xposed is a must have for me as well, but it's very buggy on 5.1 (And most CM based ROMs)
    I'm running Oxygen and Xposed perfectly, I would really recommend it. Or ParanoidAndroid
  6. roshan.india
    I believe it works well with all CM roms...as long as its 5.0.2 build :)
  7. SparkkIt
    Really? I've tried it on several and noticed that my GravityBox settings were freaking out with CM's custom settings. Bootloop city lol
    Maybe I missed something though haha
  8. roshan.india
    Nah...it's probably me :p... I've never found any use for customization apps like GravityBox when I'm in CM :p... I use other apps...like Amplify, Greenify, Minminguard, etc... and they work perfect :)
  9. frankiecortina
    Just found the super alpha .. So far so good ! Thanks !
  10. richbrown68
  11. KforHorizon
    KitKat May 27, 2015
    KforHorizon , May 27, 2015 :
    Its working perfectly fine! Flash the android sdk22 arm after installing xposed installer 3.0 alpha 2!
    Make sure which mods are working and which are not and you'll be fine!
  12. forid-786
    forid-786 , May 27, 2015 :
    Lol I don't know why you all take the 'Alpha' thing so seriously. The unofficial alpha has been working much better for me on 5.1 than how the official ever did on 5.0. It might be due to the ART improvements but 5.1 is awesome in terms of performance.
    You need the correct zip, and everything should be fine. I've got a lot of modules, a small handful don't work fully, but they're getting updated pretty fast so it's a no biggie. Btw, I'm also running resurrection remix.
    frankiecortina likes this.
  13. Adikovec
    Adikovec , May 27, 2015 :
    Xposed already in alpha,WORKS WELL ON CM12.1 (5.11) :)
  14. amoghkulkarni
    amoghkulkarni , May 27, 2015 :
    @frankiecortina
    I am using the Super Alpha too. On its XDA thread, you will also find the list of widgets that are reported working and non-working and also an easy solution to fix the bootloop (I think I read it somewhere)
    Let me know if you don't find the list there (I am typing with left hand now, would take some time for me to search and paste the url right now)
  15. frankiecortina
    How's RR treating you ? I fond it to be super customizable ! I had an issue with Google play services crashing though. How's battery life ?
    amoghkulkarni likes this.
  16. amoghkulkarni
    I am facing the infamous "Mobile Radio Active" bug. It gives me around 18 hrs uptime with 4 hrs SOT. But the mobile radio is active all the time in the background. Whatsapp is currently eating 21% battery :(
    But RR seems amazing, loads of customizations and butter smooth
  17. frankiecortina
    That's crazy
  18. amoghkulkarni
    Its hell. If i am connected to mobile data, the battery continuously drains even if the phone is idle.
    I have to either turn off data or stay in Wifi. But I can't afford to do so. I have to be connected to my mobile data for like 12 hrs.
  19. richbrown68
    richbrown68 , May 27, 2015 :
    Much better battery life than CM12.1, zero reboots (unlike several per day on CM12.1). I get 8 hours on screen battery time, compared to 6 on CM12.1.
  20. frankiecortina
    Ice Cream Sandwich May 28, 2015
    frankiecortina , May 28, 2015 :
    Really 8 ? I ( so far) have had bad battery life !
