Return back to oxygen via OnePlus Community App
  1. #1
  2. Cervantes
    Moderator Moderator Feb 20, 2021
    Cervantes , Feb 20, 2021 :
    Hi
    it is the same procedure as installing lineage
    B_Wrath and Auristic like this.
  3. lux991 , via OnePlus Community App , Feb 20, 2021 :
    Ice tried but the phone said that the oxygen that i found on the official site can be only updated but not installed by zero
    Could be the problem of the avicii recovery?
  4. Cervantes
    in OP always use recovery TWRP
    to confirm
    You enter the recovery and you cleared the cache and the system
    You have the option of dalvik or art cache
    Liehjan, lux991 and Auristic like this.
  5. #5
  6. lux991
    Donut Feb 20, 2021
    lux991 , Feb 20, 2021 :
    The problem are 2:
    - i have to install the recovery in slot a and b?
    - i'm trying to install the official zip but th error is: Flashing A/B zip to inactive slot:A
    What does it mean? That i'm using the slot A so i have to install in slot B? But the slot B has a different recovery
  7. lux991
    Donut Feb 20, 2021
    I try to explain better what ive done:
    i follow all the step of the lineage site (and use copy partitions)
    Everything ok
    ive used magisk
    ok
    Now i want to come back to oxygen
    I cannot install oxygen on partition B because is in use and partition A is unusable (is inactive)
    Could you help me to solve? Probably is a stupid fact but i really dont know haha
  8. Cervantes
    Please, You can contact support: Here
    change to your country at the bottom: the flag
    because it doesn't install a rom from the OP3
    lux991 likes this.
  9. #9
  10. lux991
    Donut Feb 23, 2021
    rhyd1am likes this.
  11. rhyd1am
    KitKat Feb 23, 2021
  12. lux991
    Donut Feb 24, 2021
    lux991 , Feb 24, 2021 :
    OK now i have another problem:
    - the phone works perfectly but i have the bootloader unlocked and some apps are locked (like netflix and bank).
    So i want to relock using fastboot or the software suggested but:
    - it is recognised in adb but not in fastboot
    - i cannot open edl mode
    Some tips?
  13. lux991
    Donut Feb 25, 2021
    lux991 , via OnePlus Nord , Feb 25, 2021 :
    Ok definitely solved.
    How?
    Changing PC!
    I have no idea why but changing the PC my phone was recognised by fastboot and not only by adb.
    Send the message
    fastboot oem lock
    You have to make a factory reset and the phone is like new.
    I hope could help someone! said:
    Bye!
    rhyd1am likes this.
