IMAK Clear Case
![[IMG]](http://i207.photobucket.com/albums/bb205/coffeeblend/OnePlus%20One/IMG_3184_zps2790b21e.jpg)
![[IMG]](http://i207.photobucket.com/albums/bb205/coffeeblend/OnePlus%20One/IMG_3187_zpsd010dbe0.jpg)
![[IMG]](http://i207.photobucket.com/albums/bb205/coffeeblend/OnePlus%20One/IMG_3188_zps6458c187.jpg)
![[IMG]](http://i207.photobucket.com/albums/bb205/coffeeblend/OnePlus%20One/IMG_3189_zps05ccb287.jpg)
![[IMG]](http://i207.photobucket.com/albums/bb205/coffeeblend/OnePlus%20One/IMG_3191_zpsbbdd311a.jpg)
Initial Impressions
Packaging is relatively decent. This case feels like a combination of the Nillkin and the Oneplus case. Design wise, it is very similar to the Nillkin, however the thickness and material is comparable to the OnePlus. Fitment fits really snug. Clear transparent back means that you can show off the One! This however is also a fingerprint magnet.
Cost
- $4.15 USD (A l i xpress - Do a search and it'll be there!)
Pros
- Aesthetically Pleasing (Heck it's basically the One with a transparent layer)
- Good protection against facing down situations
- Cheap!
- Can be customisable to your own tastes
Cons
- IMAK branding on the case
- Not as sturdy as the Nillkin
- No protection on top and bottom.
- Frontal 'tip' nearly non-existent. Case clips onto the shiny bezel of the device and just clears the height of the display. Would probably be 'protective' if you have no screen protector, however my 0.3mm tempered glass was definitely higher.
Diztronic TPU (Red)
![[IMG]](http://i207.photobucket.com/albums/bb205/coffeeblend/OnePlus%20One/IMG_3222_zps1a400229.jpg)
![[IMG]](http://i207.photobucket.com/albums/bb205/coffeeblend/OnePlus%20One/IMG_3223_zps281806d7.jpg)
![[IMG]](http://i207.photobucket.com/albums/bb205/coffeeblend/OnePlus%20One/IMG_3224_zpsa6b81ca8.jpg)
![[IMG]](http://i207.photobucket.com/albums/bb205/coffeeblend/OnePlus%20One/IMG_3225_zps00096b86.jpg)
![[IMG]](http://i207.photobucket.com/albums/bb205/coffeeblend/OnePlus%20One/IMG_3226_zpsd20f5ab0.jpg)
![[IMG]](http://i207.photobucket.com/albums/bb205/coffeeblend/OnePlus%20One/IMG_3227_zps95d1781d.jpg)
![[IMG]](http://i207.photobucket.com/albums/bb205/coffeeblend/OnePlus%20One/IMG_3231_zpsa183f372.jpg)
Initial Impressions
By far one of the best material for a case, ever! Fitment is spot-on, minor adjustment needed for the rear microphone but that isn't an issue. Phone sits inside the case real well. Only downside I can see is the bland-ness of the case (may be a good thing) and the injection mould mark. Other than that this case is worth every penny. This is also one of the two case that features buttons inbuilt in the case. Button operation is easy.
Cost
- $15.00 USD (
Diztronic Official Site) & $9.99 USD + $7 shipping (Located in NZ) - Apply discount code
XDA for a discount! REPEATBUYER for 10% off! Thanks
@ozdavo
Pros
- Strong and sturdy!
- Extra material around front of display to prevent damages from facing down situations
- Flexible material, won't crack whatsoever
- Pretty!
- Full around coverage except headphones area
Cons
- Cost (most expensive out of the whole lot)
- Injection mould mark (though not much can be done)
- Bulkier Device
