33
{Review}OPO & OPO Temper Glass..!!
  1. Mydealz
    Ice Cream Sandwich Dec 17, 2014
    Mydealz , Dec 17, 2014 :
    Don't you forget about Mocolo tempered glass.
    Just installed mine today and love it. Great fit, round edges, very nice touch to it.
  2. Sandip680
    Gingerbread Dec 18, 2014
    Sandip680 , Dec 18, 2014 :
    Well I just ordered the OPO tempered glass screen protector, based on your review... My only query is if its slim and lightweight or hard like the Nilkin one as I found that one to be hard, although honestly rugged... Is it rugged and durable enough.. Also the Nilkin One had a 1 cutout only for camera, proximity sensor and microphone.. But in this protector I see 2 cutouts for camera and area beside microphone... So can you confirm whether if the OPO one has got any cutout for proximity sensor or not???
    Lastly the Nilkin One did not cover the screen fully as there was a minor gap on the left side of the screen still left with the Nilkin... Does this One cover the screen fully or not!!!
    These are my only queries before buying as I want to be absolutely sure before buying, otherwise I will cancel the order.. Please Reply!!!
  3. AkhilReddy
    Eclair Dec 18, 2014
  4. omiroks
    Jelly Bean Dec 18, 2014
    omiroks , Dec 18, 2014 :
    1. Its hard enough( 8H Hardness )
    2.There are 2 cutouts
    • Camera
    • Headset Speaker
    3. Proximity Sensor is not covered.
    4. It is OnePlus Made so there are no visible gaps unless u observe very closely.( 0.1mm or so) the OnePlus Screen is slightly inside the outer edges of the piece and the temper glass has rounded of edges and it fits perfectly in that hole so it doesn't give the lifted screen feel which other temper glass give.
    Hope I have cleared all the doubts :D
    I did order it :p :p the moment it was available.. i had put notification for its availability and once it was i directly placed the order :p
    AkhilReddy likes this.
  5. omiroks
    As u read i bought the clear case for now i ll wait for a year or so before putting anything else....except if the launch style swaps :p
    Its nice i just saw it :) whats its hardness if u can tell me ?
  6. Mydealz
    Ice Cream Sandwich Dec 18, 2014
  7. Sandip680
    So does it anyway affect the proximity sensor??? Now I only have this query!!! Thankyou for your earlier replies!!!
    omiroks likes this.
  8. AkhilReddy
    Eclair Dec 18, 2014
    AkhilReddy , Dec 18, 2014 :
    Bro but y so you think that clear case that good?
    omiroks likes this.
  9. omiroks
    As the sensor is cover and has protection it will last longer(Smudge Effect)..!! No Noticeable aftects on the sensor.. :D
    I dont know but i ll find out ..!! :p any ways i wanted a cover and i m getting one :) Flip covers just isnt me :)
  10. GasPoweredCat
    Eclair Dec 18, 2014
  11. TheQuarterMile
    Gingerbread Dec 20, 2014
  12. Ramesh1249
    Ice Cream Sandwich Dec 20, 2014
    Ramesh1249 , Dec 20, 2014 :
    Is it anti-fingerprint
  13. omiroks
    Jelly Bean Dec 20, 2014
  14. hisam1994
    hisam1994 , Dec 20, 2014 :
    if proximity sensor is covered then i wont work na thn how
    omiroks likes this.
  15. omiroks
    omiroks , Dec 20, 2014 :
    sorry the led is covered :) not the proximity sensor and even if it was covered it hardly makes a difference its IR not the touch sensor :)
    hisam1994 likes this.
  16. hisam1994
    proximty sensor is used to sense any object near it swotches the screen off while making a call and it does the same to prevent from waking when it is in pockets etcc so it make a difference
  17. omiroks
    i knw that :p but its a glass only and opaque objects cause the sensor turn active for the screen :)
  18. AkhilReddy
    Eclair Dec 20, 2014
    AkhilReddy , Dec 20, 2014 :
    Proximity sensor is worst in opo bcz 7-10 calls went to others when it was in my pocket in two days and I'd keep a pattern it would go to emergency dialer...: p
  19. omiroks
    no problem with me :)
  20. AkhilReddy
    Eclair Dec 20, 2014
    Bro I want to get one case but I don't know which to get
    Suggest me one...
