75
[REVIEW] Orzly Temperd Glass Screen Protector
  1. gusuraman
    Community Veteran Aug 20, 2014
    gusuraman , Aug 20, 2014 :
    Yes, this forum is an english learning booster.
    I also didn't like scrren protector before... But i must say that you forget you have protector with tempered glasses
    givemeyoursoul likes this.
  2. J.Pinkman
    Jelly Bean Aug 20, 2014
    gusuraman likes this.
  3. morandero
    Eclair Aug 20, 2014
  4. Chucksaddict
    Honeycomb Aug 20, 2014
  5. Chugz
    Ice Cream Sandwich Aug 20, 2014
    Chugz , Aug 20, 2014 :
    The Casebase one is the best one, in my opinion, it's the thinnest, strongest and most oleopathic. Plus it also has that speaker cutout too.
    ganstakillerz likes this.
  6. ganstakillerz
    ganstakillerz , Aug 20, 2014 :
    I definitely agreed with you there mate.
  7. gusuraman
    I will keep this in mind when/if i will need new screen protector
    Thanks fo sharing:)
  8. Mark Joseph
    Mark Joseph , Aug 20, 2014 :
    i found out that there are 2 version of the orzly tempered screen protector,
    (the one that fits perfectly is the onethat has less color)
    the one is like the other people said 2mm short or more but the other one fits the phone like a glove,
    i ordered 1pc of them from orzly amazon, but due to a delivery mistake i got a over headted screen protector thou orzly sent me one asap.
    "for application i suggest going to the bath room and take a 10min shower to lessen the dust particles or atleast make them drop because of humidity,then apply screen protector, less dust around:D"
    edit: if you guys want to know the kingstone otg work with no app needed,
    just plug and transfer all you want,
    thou as all otg you need to remember that they do heat easily and almost instantly.,
    the cuzerlite case is wonderful even in the eye, i would recommend it.unless you want flipcase or other types, but if you are in to gel cases this one is the best imo, i had bought the orzly gel case,it was horrible, very very horrible. (the cruzerlite case has the power and voulme rocker covered in the case)
    abhimuktheeswarar and Joyyy like this.
  9. Mark Joseph
  10. gusuraman
    Very usefull info. Seams that i've been lucky:)
    I've seen you are from Italy too. So our barcodes should match.
    Can you compare if they are same code?
  11. Mark Joseph
    the other one is the same as yours but the other one is just slightly different
    the end number is 882
    that might mean another version of the product cause only reason to chage a barcode is when there are different version of the product,
    (or maybe cause the other one was ordered in amazon.de and the change one was sent from u.s)
  12. gusuraman
    So probably they aknowledge the size problem and fixed it.
    Mine is same code of the well fitting one. Right?
  13. Mark Joseph
    yes it is, i even scaled the 2 screen protector and you can see the difference with the naked eye,
    its just little aprox 2 1/2 overlaped fingernails
  14. Mark Joseph
    ah i forgot to say i bought the first one (shorter one) back about 2 months ago,
    then the new one arrived today (the fitted one)
  15. Cryptworks
    Gingerbread Aug 20, 2014
    Cryptworks , Aug 20, 2014 :
    I went and bought this for my 1+ and its fit is amazing, to the point of being unnoticeable. and the visual clarity is spectacular.
    Also one of the easiest to install so far.
  16. volksjager
    Froyo Aug 20, 2014
    volksjager , Aug 20, 2014 :
    I like this screen protector very much but my only worry is whether it is compatible with my Dizitronic tpu gel case ? Are you using any tpu case ? Please let me know.
    Headbouncer likes this.
  17. volksjager
    Froyo Aug 20, 2014
    Are you using cruzerlite tpu case with orzly screen protector ?
  18. ezehelm
    ezehelm , Aug 20, 2014 :
    What's wrong with the Nillkin screen protector? :eek:
    #38
  19. gusuraman
    no, I don't use any case.
    Se the links list in my signature. Maybe there you can find somebody with both
    #39
    volksjager likes this.
  20. gusuraman
    Nothing. It's very good too reading users reviews
    #40
