128
Rhinoshield and Dbrand combo review
  1. C1529097723983 Cupcake Feb 20, 2019
    #41
  2. C1545017676351 Gingerbread Feb 20, 2019
    C1545017676351, Feb 20, 2019 :
    I'm having a query. this process involves heating the device between 80 to 90 degree Celsius to remove the existing back cover.
    due to heat, what's happens to the electronic components life? does it affect?
    #42
  3. Trithesh onkar Eclair Feb 20, 2019
    #43
  4. Sukandan Cupcake Feb 20, 2019
    Sukandan, Feb 20, 2019 :
    I do have 6T too, are you using tempered glass? if so do mention the brand. I am annoyed with the Oneplus' black bordered tempered glass. it just blocks the curvy screen
    #44
    Gangada Suresh Kumar likes this.
  5. NavdeepSinghSurd Cupcake Feb 20, 2019
    NavdeepSinghSurd, Feb 20, 2019 :
    Using the Unicorn Beetle Pro case for more than a year now....it does make the device huge but does the recommended work...
    will suggest a skin also though...coz the back of 5t is pretty bad and looks withered after some time if you use the regular case provided....
    hope that helps
    regards
    Navdeep
    #45
  6. Bloodlust Froyo Feb 20, 2019
    #46
  7. Moin2200 KitKat Feb 20, 2019
    Moin2200, Feb 20, 2019 :
    One UI icon pack.
    #47
  8. Moin2200 KitKat Feb 20, 2019
    I don't have any tempered glass on but I've ordered the dbrand prism screen protector which should be a better option than most brands.
    #48
    Sukandan likes this.
  9. G_Boris_Sweden_lHuW Gingerbread Feb 20, 2019
    #49
  10. 956400 Cupcake Feb 20, 2019
    956400, Feb 20, 2019 :
    has anyone tried using the Rhinoshield Solidsuit WITH the dbrand skin, for extra extra protection? would it even make sense?
    I know that's a pricey solution, and it defeats the purpose of dbrands awesome skin design, but with an all-glass phone one can never have too much protection.
    so my question is, would the solidsuit even FIT over the dbrand skin?
    #50
  11. G_Prashant_Dixit_Qvov Cupcake Feb 20, 2019
    #51
    D1541981280738 likes this.
  12. G_Prashant_Dixit_Qvov Cupcake Feb 20, 2019
    #52
  13. Adex0ne Ice Cream Sandwich Feb 20, 2019
    Adex0ne, Feb 20, 2019 :
    I use dbrand's skin also for proper grip due to the shiny glass back of the 6t, and due to my type of work being an engineer,I need more than a rhinoshield case, I need an overall protection, h nice I only use my phone bear bone when I'm off work or with my friends but at what ek, always protected, 3years is my minimum number of years of using a device before u start thinking of an upgrade
    #53
  14. D1541981280738 Eclair Feb 20, 2019
    #54
  15. RobinJones Froyo Feb 20, 2019
    #55
  16. Shivar911 Eclair Feb 20, 2019
    Shivar911, Feb 20, 2019 :
    pretty good combination, I wish I could get the yellow but a friend beat me to it[e]1f62a[/e]
    #56
  17. diegofernandezkim Cupcake Feb 20, 2019
    diegofernandezkim, Feb 20, 2019 :
    he might be using Microsoft launcher.
    #57
  18. Y1530638559797 Eclair Feb 20, 2019
    #58
  19. ChinmayaHunagund Donut Feb 20, 2019
    #59
  20. Priyanshu Sharma Ice Cream Sandwich Feb 20, 2019
    #60
