128
Rhinoshield and Dbrand combo review
  1. Mateus Carvalho
    Cupcake Mar 14, 2019
    Mateus Carvalho , Mar 14, 2019 :
    Hey there. Nice review, phone looking good.
    How harder to press are the buttons with the Rhinoshield Bumper case?
    Is it really that hard to remove? is there any chance of it damaging the phone when removing?
  2. A1550545539624
    A1550545539624 , Mar 14, 2019 :
    No you can't damage the phone but can damage if you have the skin on the back because it is extremely tight on the phone. And also buttons is not easy to press.
  3. Moin2200
    KitKat Mar 16, 2019
    Moin2200 , Mar 16, 2019 :
    Not really it’s really easy to remove and put on, but I think it works well because my skin was put on perfectly. Because some people have reported that the skin gets lose when the case is removed.
    The buttons feel a bit tighter but after a day or so you get used to it and the buttons becomes more lose.
  4. A1550545539624
    Cupcake Mar 21, 2019
    A1550545539624 , Mar 21, 2019 :
    I tried to use this rhinoshield on my dbrand skin and almost damaged the skin because it is too tight. I don't recommend to use with any skin. Before i had cheap one so did not care.
  5. Y1553350839509
    Cupcake Mar 23, 2019
  6. A1550545539624
    Cupcake Apr 14, 2019
    A1550545539624 , Apr 14, 2019 :
    I do not recommend to use this case with any skins, wraps it will only damage. I have #dbrand skin and now i have deep grooves in the skin where the case was sitting on also skin from the corners is now little bit peeling off. It is because the case is way too tight and the plastic of the case is made from hard material. I can't show because i don't have other phone but it looks bad. It is not the only problem with this case also side button is really hard to press and for £20 it not worth it.
  7. Jew4OnePlus
    Cupcake Apr 25, 2019
  8. Vikzi711
    Cupcake May 10, 2020
    Vikzi711 , May 10, 2020 :
    Quick question. Are you worried about the camera lens getting scratched from constantly being taken in and out of your pocket? Have you seen any scuffs on your lens because of this? That's the main thing holding me off of a bumper+skin combo.
