Ringer volume decreases by itself
  1. nuno10costa
    Cupcake May 8, 2020
    nuno10costa , May 8, 2020 :
    Hi all.
    I'm having an issue with my brand new OnePlus 7T.
    Out of nowhere, the ringer volume is changing to zero. I'm missing calls because it just won't ring... I can turn it all the way to the maximum in the settings, but a few moments later it goes down again.
    Note: the slider is in the ring position.
    Any solution for this? I can't have a phone if I'm constantly loosing calls...
    Thanks
    Metrivet likes this.
  2. clspriggs
    Cupcake Jul 1, 2020
  3. gpbasley
    Cupcake Sep 4, 2020
    gpbasley , Sep 4, 2020 :
    Same here. I do notice that incoming calls, even texts, seem to reset the ring volume to low.
    Of course, OnePlus is just a cell phone company, and will never help resolve the issue, because their entire help system, like every other tech company, is designed to keep you from getting a complaint resolved, unless the phone burnes down a thousand houses or something like that. No, I am not anti-OnePlus. Good phone generally, but why can't they fix a ******* problem like this? Google the same with Android Auto: has sucked for years. Still sucks.
  4. Metrivet
    Cupcake Sep 4, 2020
    Metrivet , via OnePlus 7T , Sep 4, 2020 :
    I had similar problem using my google play music, it suddenly dropped from playing via my wired headphones to silence and when i raised the volume again, it happened again... But after rebooting the phone its ok
  5. sean_nolan
    Eclair Sep 5, 2020
    sean_nolan , via OnePlus 5 , Sep 5, 2020 :
    Its a setting in android to automatically reduce the volume of the ringer. Go to the phone app>settings>sound and vibration>raise to lower ringtone (disable this one)
  6. sean_nolan
    Eclair Sep 5, 2020
  7. sean_nolan
    Eclair Sep 5, 2020
  8. danx55
    Donut Jun 15, 2021
    danx55 , Jun 15, 2021 :
    hi - ive had similar issue with ringer ....just goes silent on me after about 1 week of uptime :/ .... only fix is a reboot ...OP support told me to wipe the rom cache and data before.....its a bit extreme but it does 'fix' problem for a few months ....its a bit of a pita tho :(
    cheers
  9. dastagir.barish
    Cupcake Jun 15, 2021
  10. danx55
    Donut Jun 16, 2021
    danx55 , Jun 16, 2021 :
    thanks .... but just checked on my v11 os 7t and i dont see that setting ...plus for up to 10 days after reboot it does ring ok ....then just stops .....so seems a bit more random than a normal setting maybe :/
  11. danx55
    Donut Jun 17, 2021
  12. #12
    danx55 likes this.
  13. Gurudev_Reddy_Marthala_ , via OnePlus 7T Glacier Blue , Jun 18, 2021 :
    While ringing the mobile u pick the mobile automatically sounds decrease to low
    danx55 likes this.
  14. danx55
    Donut Jun 18, 2021
    danx55 , Jun 18, 2021 :
    got it thanks ...was looking in the main sounds settings and not in the phone app :D .... have unticked both of those now
    cheers
  15. danx55
    Donut Jun 24, 2021
  16. AlwaysOneplus
    Gingerbread Jun 29, 2021
  17. danx55
    Donut Jul 13, 2021
