3
Ringtone Volume isaue
  1. laxmikant.b2
    Donut Jun 11, 2018
    laxmikant.b2 , Jun 11, 2018 :
    In the ota they said that ringtone and speaker volume will be improved. I can't notice it. Have you noticed?
  2. Bmuellerleile
    Donut Jun 11, 2018
  3. Natje049
    Eclair Jun 11, 2018
    Natje049 , Jun 11, 2018 :
    It has been increased indeed. But the ringtone volume is now too loud for me at 14% minimum
    infinityplus1 likes this.
  4. infinityplus1
    Honeycomb Jun 11, 2018
    infinityplus1 , Jun 11, 2018 :
    It's now too loud for me too. I've had to disable most notification sounds or use the alert slider to keep it quiet.
    There's no need for the whole house to hear when I receive a message (neighbours too)
    REAL6 and Natje049 like this.
  5. Sunil_82
    Donut Jun 11, 2018
  6. Abul Kalam Azad
    Donut Jun 12, 2018
  7. Prcko
    KitKat Jun 12, 2018
    Prcko , Jun 12, 2018 :
    dear users did you received new update? if "no" wait and don't open new thread
  8. Sandip B
    Cupcake Jun 12, 2018
  9. Liehjan
    Lollipop Jun 12, 2018
    Liehjan , Jun 12, 2018 :
    Maybe your volume was normal to begin with, and the update did nothing to your device?
  10. T1528728308760
    T1528728308760 , Jun 12, 2018 :
    it has increased significantly .For the ones who are facing hard time with increased volume ,u have settings to decrease it too. FYI
  11. laxmikant.b2
    Donut Jun 12, 2018
    laxmikant.b2 , Jun 12, 2018 :
    I have received and installed aready
  12. Prcko
    KitKat Jun 12, 2018
    and you still have a same problem? many users reported this problem was solved. do you wipe cache in recovery after update? do you try to change ringtone?
  13. PuCiNhOOO
    Gingerbread Jun 12, 2018
    PuCiNhOOO , Jun 12, 2018 :
    Impossible!!!
    What build are you on? 5.1.5?
  14. rubencdl
    Froyo Jun 12, 2018
    rubencdl , Jun 12, 2018 :
    On Oxygen 5.1.6 the ringtone is pretty loud, if you expected higher volume better pay a visit to the doctor.
    Blue_Blurr likes this.
  15. leeperks86
    Froyo Jun 12, 2018
    leeperks86 , Jun 12, 2018 :
    It's quite a bit louder and I definitely prefer it for when out and about should be a lot easier to hear. If your in a fairly quiet place I can understand why it might be "too" loud, but that's why you have volume controls.
  16. PuCiNhOOO
    There is no volume control possible when you are already on the minimum that the phone can get
