ringtones problem
  1. L1595499161975
    Cupcake Oct 30, 2020
    L1595499161975 , Oct 30, 2020 :
    sir,
    when I get a call then the ringtone go low to high and when I pick the phone in hand then the ringtone sound gone low . I want to know is that a problem?
  2. the_o2
    User of the Year 2018; Community Scholar 2020 Oct 30, 2020
    the_o2 , Oct 30, 2020 :
    No it according to settings,
    You can change these settings from here
    Click on the phone dialer app
    3 dots on top right corner
    Settings
    Sounds and vibration
    Here you find two option called as Ascending ringtone volume and Raise to lower ringtone.
    Enable or disable according to your need.
  3. L1595499161975
