171
Rollback Build for OnePlus 6 and 6T open beta testers
  1. B_Wrath
    Junior Moderator Junior Moderator Apr 24, 2020
    B_Wrath , Apr 24, 2020 :
    Restart the phone and now don't check build in app updates.
    Caoimhín likes this.
  2. Priyankgohil 10
    Froyo Apr 24, 2020
  3. prkoparkar
    Froyo Apr 24, 2020
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 24, 2020
    Caomhin , via OnePlus 6T , Apr 24, 2020 :
    ROLL-BACK FROM CURRENT ANDROID 10 Beta or Stable TO EARLIER STOCK ANDROID 9 OR 10
    Thanks to @ironass for putting this together.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    All Downgrades to earlier builds involve wiping the phone. So you will need to backup your phone data.
    If you can, it's always better to wait for newer Stable build, as it should upgrade to newer build version without Data loss.
    And its always good practice to backup phone data before upgrading.
    ironass likes this.
  5. P1552830417745
    Cupcake Apr 24, 2020
    P1552830417745 , Apr 24, 2020 :
    Lag raha hia OnePlus jhatu ho gya hai.ab OnePlus ki koi mobile nahi leni hai.chutiyapa ki bhi had hoti hai yaar.
    Danny_boy likes this.
  6. Caomhin
    Who knows, contact OP directly to find out, good luck getting an answer. As that road map has not been written yet.
    Priyankgohil 10 likes this.
  7. Priyankgohil 10
    Froyo Apr 24, 2020
    Priyankgohil 10 , via OnePlus 6 , Apr 24, 2020 :
    lol
    we can still get android 11 dp 2 unofficially
  8. Caomhin
  9. Priyankgohil 10
    Froyo Apr 24, 2020
  10. Caomhin
    Came as part of new OnePlus Launcher. So it should carry forward.
  11. ironass
    Lollipop Apr 24, 2020
    ironass , Apr 24, 2020 :
    What... you mean like Tom Cruise, Dwayne Johnson, Brad Pitt, etc: Thanks! :D
  12. surendra91
    Honeycomb Apr 24, 2020
    surendra91 , Apr 24, 2020 :
    u wc
  13. Priyankgohil 10
    Froyo Apr 24, 2020
  14. B_Wrath
    There is no guarantee that the features of OB6 will be in the next stable build.
    ironass likes this.
  15. Priyankgohil 10
    Froyo Apr 24, 2020
  16. B_Wrath
  17. Priyankgohil 10
    Froyo Apr 24, 2020
  18. Caomhin
    Personally I would wait, you still have use of the current features in Beta 6 which are not available in 10.3.2. Then Manually upgrade with the newer version stable when it comes out.
  19. Caomhin
    It must have a sad life if all it can do is be a stalker to folks on here. 🤣🤣
    ironass and B_Wrath like this.
