171
Rollback Build for OnePlus 6 and 6T open beta testers
  1. SpandanAthaide
    Cupcake Apr 25, 2020
    SpandanAthaide , via OnePlus 6 , Apr 25, 2020 :
    Guys, if I wait for the next stable release for OP6 and then if I directly install that full zip via local upgrade over my current Open Beta 6, will that get me back to the stable channel without data loss(Files/Media in internal storage)??
  2. sonu2511
    sonu2511 , Apr 25, 2020 :
    I have backup my data I got everything back instead my notes which I also backup how can I get the backup of notes
  3. kouzelnik3
    Ice Cream Sandwich Apr 25, 2020
    kouzelnik3 , Apr 25, 2020 :
    Yes
    SpandanAthaide likes this.
  4. Tee_Eee_Bee
    Tee_Eee_Bee , via OnePlus 6T , Apr 25, 2020 :
    Did you remove the '.jar' from the filename?
    You can do this in your file manager
    drl431 and Caoimhín like this.
  5. Tee_Eee_Bee
    In the past, installing a version of OOS with a newer build date did not result in data loss, so in theory it should be ok.
    Having said that, when you do install the newer stable version, it's still good practice to back up your data just in case.
    ronaksworld, drl431, B_Wrath and 3 others like this.
  6. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 25, 2020
    Caomhin , via OnePlus 6T , Apr 25, 2020 :
    Try this, if you are having difficulty.
    ROLL-BACK FROM CURRENT ANDROID 10 Beta or Stable TO EARLIER STOCK ANDROID 9 OR 10
    Thanks to @ironass for putting this together.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    All Downgrades to earlier builds involve wiping the phone. So you will need to backup your phone data.
    If you can, it's always better to wait for newer Stable build, as it should upgrade to newer build version without Data loss.
    And its always good practice to backup phone data before upgrading.
    drl431, Ronesso17 and ironass like this.
  7. Smnoe
    Donut Apr 25, 2020
    Smnoe , via OnePlus 6T , Apr 25, 2020 :
    completely understand closing the beta, however, not happy with having to roll back my device. why not simply make the next stable version higher than the beta to allow us all to move over seamlessly?
  8. Feodor_Burov
    Donut Apr 25, 2020
    Feodor_Burov , via OnePlus 6 , Apr 25, 2020 :
    SpandanAthaide
    Guys, if I wait for the next stable release for OP6 and then if I directly install that full zip via local upgrade over my current Open Beta 6, will that get me back to the stable channel without data loss(Files/Media in internal storage)??​
    You Will Lose your Data !!![e]26a0[/e]️[e]26a0[/e]️[e]26a0[/e]️
    You will lose all !!
    Beta = beta ( without lose )
    Stable = Stable (without lose )
    Beta + stable ( You will lose all)
    Caoimhín likes this.
  9. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Apr 25, 2020
    Artemus , Apr 25, 2020 :
    Because it's not available yet. You can wait for it to release, you don't have to rollback RIGHT NOW.
    By installing Google Keep.
  10. Caomhin
    It will be Stable higher and you can stay on Beta 6 until it is released.
    As usual it will be an incremental update first for this already on Stable 10.3.2, then the full file update will come out about a week or so later, you can install with that Full update.
    Smnoe likes this.
  11. Caomhin
    Yes it should.
  12. Smnoe
    Donut Apr 25, 2020
    Kytharsis
    By installing Google Keep.​
    it might be worth mentioning this as an option in the original thread, so much more can go wrong restoring a devices apps unless absolutely necessary I don't see a reason to do it. yes, there is always a risk when moving between build, but those risks are accepted as as of becoming a beta tester.
    ideally, OnePlus would have notified this is the last openbeta build when releasing it so that we could make an informed decision as to whether to go on it or not. I for one moved over from stable to beta on this build. at the very least announce the closure of the program with a incremented stable version to upgrade to
  13. Artemus
    So... you're mad that they didn't tell you beforehand?
  14. Smnoe
    Donut Apr 25, 2020
    why would I be mad, why the sudden escalation, it's only a phone? just added some constructive feedback. I don't want to wipe data unless absolutely necessary. appreciate the previous comments to assist could wait for the next stable, not ideal, but will have to do
  15. Artemus
    I'm gonna assume you didn't wipe after updating to A10 either?
  16. Anmol 45
    Honeycomb Apr 25, 2020
    Anmol 45 , Apr 25, 2020 :
    hey I've backed up...and restored my data after the rollback using OnePlus switch. I see that the images, documents and videos are back, and a few system settings are back to normal. But, there are no apps installed. Why is this? Does it take some time?
  17. Artemus
    Download them manually.
  18. Smnoe
    Donut Apr 25, 2020
  19. Artemus
    And you've not had any issues with restarts or lags or anything of the sort?
  20. Smnoe
    Donut Apr 25, 2020
    No, it's been working perfectly.
