138
Rollback Build for OnePlus 6 and 6T open beta testers
  1. Caomhin
    Lollipop May 14, 2020
    Caomhin , via OnePlus 6T , May 14, 2020 :
    Go to both locations and login to both Google Photos and Google drive in an external browser, you should be able to see what's backed up there.
    I never use OnePlus Switch due to the issues it has, only ever use Google Backup and Sync. As it backs up practically everything. You can set what to back up in the Google Sync settings.
  2. Bladesss
    Cupcake May 14, 2020
    Bladesss , May 14, 2020 :
    But I had a running backup account Google, but it does not restore the application data too;/
  3. Bladesss
    I had to restore the phone to factory settings and the first time you turn on the question appears whether I want to transfer data from another phone ... Earlier I chose "No" (because I wanted use Oneplus Switch) and after choosing "Yes" appears the option to restore from a copy in the cloud ... Massacre, what a moron invented the content of the message ... Now i waiting to install app from backup
    Edit: google backup also did not restore data from google authenticator.
    The person who wrote the instruction from the first post should be fired from job! It should contain information that oneplus switch DOES NOT RESTORE APPLICATION DATA AND ONLY THE SAME APPS !!!! ITS'S FU-CK-ING TRAGEDY FOR ME, I HAVE FUC-KED!!!!!!!!!!!!!!!!
  4. Artemus.
    Nougat May 14, 2020
    Artemus. , May 14, 2020 :
    Dude... app data is expendable, most of it is saved server-side. All you need to do is redownload the app and log into the appropriate account; all your stuff should still be there. Otherwise, switch to a different authenticator app like Authy.
    Caomhin likes this.
  5. Bladesss
    Bladesss , via OnePlus 6T , May 14, 2020 :
    Bullshit. A lot of data is stored in internal memory. If a ram wrote the correct instruction, I would temporarily disable 2fa on relevant portals. Now I have to change the Authenticator for something else? Now?? When did I lost access ?? In addition, I lost a lot of important saved data in the browser, it has not been restored either. Oneplus Switch is a ****-ing crap!
  6. Artemus.
    Nougat May 14, 2020
    You even know what Google Authenticator does? All it does is spit out a code. Everything is saved server-side.
    Caomhin likes this.
  7. Caomhin
    Never rely on just one backup option, learned that a long time ago, always have at least 2 backup options for everything. It's a given that one will fail at some stage.
    It's a learning process, best to put it down to experience and move on. It's a hard lesson, but they are usually the best ones, you never forget that lesson. [e]1f44d[/e]
    ironass and Artemus. like this.
  8. Bladesss
    Cupcake May 15, 2020
    Bladesss , via OnePlus 6T , May 15, 2020 :
    I did two different backups...
  9. Thenili2926
    Cupcake May 16, 2020
  10. Artemus.
    Nougat May 16, 2020
    Artemus. , May 16, 2020 :
    Um. What do you mean?
    Caomhin likes this.
  11. Thenili2926
    Thenili2926 , via OnePlus 6T , May 16, 2020 :
    I mean I feared to update to android as cellphone become so unstable after update, so I only want to update security patches to latest.. is it possible?
  12. Artemus.
    Nougat May 16, 2020
    Nope! Security patch updates come packaged with everything else. Maybe explain the "unstable" parts?
    Caomhin likes this.
  13. Thenili2926
    ok got it.. last question. is my phone vulnerable to cyber theft if I don't update to latest Android?
  14. Pedrito_pg
    Eclair May 16, 2020
    Pedrito_pg , via OnePlus 6T , May 16, 2020 :
    im on that 10.3.0 and man am i stable. look at this battery life too
  15. Artemus.
    Nougat May 16, 2020
    ironass and Caomhin like this.
  16. Pedrito_pg
    Eclair May 16, 2020
  17. S1537548158924
    Cupcake May 17, 2020
    S1537548158924 , May 17, 2020 :
    @Manu J. : I tried these,
    How to rollback your device
    1. Download the appropriate rollback package - OnePlus 6 or OnePlus 6T
    2. Open the File Manager and move the downloaded .zip package from the Downloads folder to the root directory.
    3. Open Settings - System - System updates, press the cogwheel on the top right corner, choose the Local upgrade option and select the rollback file.
    Then clicked on Reboot, then I got bootloader menu and I am stuck in here.
    What should I next?
    My initial problem was that 10.3.3 in OP6 was powering off my phone continuously, https://forums.oneplus.com/threads/oneplus-6-suddenly-switched-off-problem.1227786/
  18. Tee_Eee_Bee
    Honeycomb May 17, 2020
    Tee_Eee_Bee , via OnePlus 6T , May 17, 2020 :
    One thing to try might be this:
    https://forum.xda-developers.com/oneplus-6t/how-to/tool-6t-msmdownloadtool-v4-0-oos-9-0-5-t3867448
    It should restore your phone to Android 9 (9.0.2), then you should be able to update to whatever version you like via OTA.
    Artemus. likes this.
  19. S1537548158924
    Thank you, mine is OP6. However if we unbrick the mobile, then I will have issues in warranty and I will not be able to get my phone repaired using the OnePlus Service Centers correct?
  20. Tee_Eee_Bee
