153
Rollback Build for OnePlus 6 and 6T open beta testers
  1. JohnBebe
    Cupcake Jun 13, 2020
    JohnBebe , via OnePlus 6T , Jun 13, 2020 :
    My 6t is like the day it came out of the box (updates up to date) and I like it. One Plus can give me a new phone I will not pay for it...now.
  2. Hmoda_Alex
    Cupcake Jun 23, 2020
    Hmoda_Alex , via OnePlus 6T , Jun 23, 2020 :
    My phone was on the beta and haven't received updates for a while, so i read in a thread that the beta program stopped and i have to move manually to a stable firmware by downgrade then update but this method will wipe data but i saw someone here said that i can download the latest firmware and install it by local upgrade without losing data, i did so and didn't lose data but my gallery app isn't showing pictures and i can't take screenshots and even Google photos app not working, how can i fix this? Should i downgrade?
  3. Hmoda_Alex
    Raise
    gallery and file manager not showing anything.
    unable to take screenshots.​
    I have same issues, i went from beta to 10.3.4 directly and Google photos not working too, did you manage to fix it?
  4. drl431
    Nougat Jun 23, 2020
    drl431 , Jun 23, 2020 :
    This is a common issue when changing the OOS version this way. For a fix, read the second post, by @B_Wrath in this thread:
    https://forums.oneplus.com/threads/oxygenos-10-3-3-for-the-oneplus-6-and-6t.1218405/
    ironass likes this.
  5. Hmoda_Alex
    drl431 likes this.
  6. śhãšhî_chinnu
    śhãšhî_chinnu , Jun 23, 2020 :
    my phone got an issue that is while clearing recent apps my phone getting freeze and all apps were restarting [e]1f614[/e]
  7. drl431
    Nougat Jun 23, 2020
    Try clearing the cache for the OnePlus Launcher app, then restart the phone.
  8. śhãšhî_chinnu
    im already done that one but no use i rebooted the phone by pressing the volume down+power button n cleared the cache buy again it was happening like that only always freezing 10 times per day
  9. Raise
    Raise , Jun 23, 2020 :
    yes.
    i had reset my oneplus fully,afterthat it is working nicely
  10. Hmoda_Alex
    Someone said clearing download app data will solve it and it actually worked
    Raise likes this.
  11. drl431
    Nougat Jun 23, 2020
    Clearing system cache wont help as the OP6 and newer phones do not have a recovery partition. You may have a misbehaving 3rd party app. Consider a factory reset. Backup your data (except the apps) to the cloud or a pc first. Don't backup and restore the apps, as you could reintroduce your issue.
    Caomhin, ironass and Dresa91 like this.
  12. pawan9525
    Donut Jun 23, 2020
  13. Caomhin
    Marshmallow Jun 24, 2020
    Artemus. and ironass like this.
  14. V1537591019064
    Eclair Jun 26, 2020
    V1537591019064 , Jun 26, 2020 :
    after download file in JAR farmate so the file will not show in local upgrade so click on file and click on rename. remove JAR AND TYPE ZIP after its change to zip file after it will show in local upgrade .
  15. V1537591019064
    Eclair Jun 26, 2020
    go settings and click on about phone and click on build number 3 or 5 times after it will say you are get developer option
  16. oprajapati
    Cupcake Jun 26, 2020
    oprajapati , Jun 26, 2020 :
    Hi!
    I have two different files downloaded when I clicked the link to download the rollback package for the OnePlus6t.
    One is titled:OnePlus6TOxygen_41_OTA_065_all_2004012104_99c690dbd1189a1.zip
    The other is titled:
    OnePlus6TOxygen_34_OTA_044_all_2002220041_downgrade_3e5565c392d047d7.zip.jar
    Which one do I download from system updates?
  17. Artemus.
    Nougat Jun 26, 2020
    Artemus. , Jun 26, 2020 :
    Are you trying to downgrade or upgrade?
    Caomhin, drl431 and ironass like this.
  18. V1537591019064
    Eclair Jun 28, 2020
    V1537591019064 , Jun 28, 2020 :
    did you see there Jar click on rename and remove jar word
  19. V1537591019064
    Eclair Jun 28, 2020
    1st one
  20. dragonfan
    Froyo Jul 24, 2020
    dragonfan , Jul 24, 2020 :
    hey guys, i need help. i downloaded the .zip file, moved into the internal sotrage but can't find it when i go to "local upgrade". any help?
