153
Rollback Build for OnePlus 6 and 6T open beta testers
  1. Cervantes
    Lollipop Moderator Jul 24, 2020
    Cervantes , Jul 24, 2020 :
    Hi
    look at the previous post
    Caomhin likes this.
  2. dragonfan
    Froyo Jul 24, 2020
  3. Artemus.
    Nougat Jul 24, 2020
    Caomhin likes this.
  4. phemt
    Ice Cream Sandwich Jul 24, 2020
    phemt , via OnePlus 6 , Jul 24, 2020 :
    In which folder?
  5. dragonfan
    Froyo Jul 24, 2020
    dragonfan , Jul 24, 2020 :
    no folder, just dropped it in internal general storage
    Caomhin likes this.
  6. phemt
    Pay attention if it is into sdcard folder.
  7. Tee_Eee_Bee
    Ice Cream Sandwich Jul 25, 2020
    Tee_Eee_Bee , via OnePlus 8 Pro , Jul 25, 2020 :
    Also, check to make sure there is no '.jar' file extension.
    If there is, use file manager to rename the file and remove it.
  8. phemt
    phemt , via OnePlus 6 , Jul 25, 2020 :
    You quoted the wrong guy :D
    Artemus. likes this.
  9. G1595845830970
    Cupcake Jul 31, 2020
    G1595845830970 , Jul 31, 2020 :
    hi, i recently purchased oneplus 6(a6000).it is still running on oxygen os beta 4 and android 9(september 2018 security patch level).can i download from file mentioned in link thread and get my phone updated????
    please reply fast
  10. Caomhin
    Marshmallow Jul 31, 2020
    Caomhin , via OnePlus 6T , Jul 31, 2020 :
    If you have a OnePlus 6 you need to download and install OOS 9.0.9 as this contains files to allow you to update to Android 10.
    Download 9.0.9 for OnePlus 6 from link below.
    https://oneplusupdates.com/device/oneplus-6
    Then download the Android 10 file for your model, follow the instructions given on the OnePlus Software Support page, link below. Then once installed you can OTA to 10.3.4
    https://www.oneplus.com/support/softwareupgrade
    drl431, G1595845830970 and ironass like this.
  11. G1595845830970
    instead can I download OnePlus 6 oxygen OTA 044 all 2002220042 downgrade 137f7ddo50eb47aa.zip and install????
    Caomhin likes this.
  12. Caomhin
    You need to go through the downgrade procedure if you want to install an older version.
    See the steps in the link below.
    ROLL-BACK FROM CURRENT ANDROID 10 Stable TO EARLIER STOCK ANDROID 9 OR 10
    All Downgrades to earlier builds involve wiping the phone.
    So you will need to backup your phone data.
    Thanks to @ironass for putting this together.
    This Link will guide you through the Downgrade process.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    ironass likes this.
  13. Vivek_Kumar...
    Donut Aug 18, 2020
  14. Tee_Eee_Bee
    Ice Cream Sandwich Aug 18, 2020
    Artemus., Vivek_Kumar... and Caomhin like this.
  15. Vivek_Kumar...
    Donut Aug 18, 2020
  16. G_Nitish_Jain_Pdrg
    Cupcake Aug 30, 2020
  17. Tee_Eee_Bee
    Ice Cream Sandwich Aug 30, 2020
    Tee_Eee_Bee , Aug 30, 2020 :
    The link in the first post worked for me, try opening it in a browser instead of the community app.
    If that doesn't work, try this link:
    https://oxygenos.oneplus.net/fulldowngrade_wipe_MSM_17819_181025_2315_user_MP1_release.zip
    from here:
    https://forum.xda-developers.com/oneplus-6t/how-to/guide-rollback-downgrade-oos-android-10-t4000645
    Instructions should be the same for the 6 as for the 6T. The link is what they have linked for the 6.
  18. AliAOmran
    Cupcake Sep 14, 2020
  19. Caomhin
    Marshmallow Sep 14, 2020
    Caomhin , via OnePlus 6T , Sep 14, 2020 :
    All Downgrades to earlier and other builds involve wiping the phone.
    RomaSoul and ironass like this.
  20. RomaSoul
    RomaSoul , via OnePlus 6 , Sep 14, 2020 :
    thank you very much, it worked no problems
    I was on H2os 10.0.5 revert to android 9 o2os then updated to the latest android 9 version and then to the latest android 10
    very easily just followed the instructions
    I was hesitant because it didn't say anything about coming from H2os to O2 os but no problem here
    ironass and Caomhin like this.
