rollback to android 10 issue via OnePlus 7
  1. VikrantPandey
    Cupcake Nov 29, 2019
    M1530754095077 likes this.
  2. MATTEO182000
    Donut Nov 29, 2019
    MATTEO182000 , via OnePlus 7 Pro , Nov 29, 2019 :
    Hi, to do the downgrade I used another file called "full downgrade" which you can find in a community thread. I downgraded with the file I mentioned to you and now I'm at the first Oxygen OS 9.5.1.
  3. MATTEO182000
    Donut Nov 29, 2019
  4. MATTEO182000
    Donut Nov 29, 2019
  5. VikrantPandey
    Cupcake Nov 30, 2019
  6. VikrantPandey
  7. Sumedh_Nadgir
    Gingerbread Nov 30, 2019
    Sumedh_Nadgir , via OnePlus 7 , Nov 30, 2019 :
    You cant rollback to lower version without full wipedown. Check the thread to downgrade which has the appropriate file and then use local upgrade. Better solution if not comfortable is to go to a OnePlus authorised service center. 10mins and your work is done
    Q1566979348476 likes this.
  8. MATTEO182000
    Donut Nov 30, 2019
  9. Didit_Anshari
  10. MATTEO182000
    Donut Nov 30, 2019
    MATTEO182000 , via OnePlus 7 Pro , Nov 30, 2019 :
    Actually no, I've never had any problems with android 10. Perfect autonomy, no slowdown. I downgraded out of curiosity, as many complained about autonomy. I have been with version 9.5.1 since three days and I find no difference and no improvement. The only thing that has improved is the speed with the biometric sensor, otherwise it is the same. In my opinion android 10 is free of bugs.
    if you have battery problems, I only recommend that you reset with wipe cache and data, not downgrade.
    If you have other questions, let me know, I'll be happy to help you.
  11. VikrantPandey
    Cupcake Dec 1, 2019
    VikrantPandey , via OnePlus 7 , Dec 1, 2019 :
    yes one app is not working in android 10 and it is very important for me so i want to downgrade
  12. kmaier
    Honeycomb Dec 1, 2019
    kmaier , via OnePlus 6 , Dec 1, 2019 :
    my fingerprint on my work app worked on 10 beta1 and stable but now on beta 2 it says there is a hardware incompatibility. weird. is it easy to roll back to stable 10?
