15
Rollback to CM11s from CM12 with a single click.
  1. pmdsp
    Honeycomb Apr 25, 2015
    pmdsp , Apr 25, 2015 :
    If for some reason you want to rollback to CM11s from CM12 here is the easy method for you.
    This method will wipe your device and restore it STOCK CM11s. Please backup your data.
    1, Download the stock fastboot rom zip file, unzip and keep it on your desktop.
    CM11s Stock Mega Link
    CM11s Stock Google Drive
    2, Put your phone on fastboot mode. (Disconnect the phone from the computer if connected power off your phone, hold VolumeUP+Power button simultaneously till you see fastboot.)
    3, Install ADB drivers if you don't have it already > ADB Drivers Link
    4, Depending on phone version run the.bat file with a double click 16gb Model or 64gb Model.
    Note: The script will unlock the bootloader first before installing the CM11s. Just follow the on screen instructions. If the phone reboots after unlocking the bootloader then just disconnect the phone put it back to fastboot mode and connect the script should continue installing the CM11s.
    If you already have unlocked bootloader there will be no interruption the script will install the CM11s and the phone will reboot into STOCK CM11s.
    Credit > https://forums.oneplus.net/threads/how-to-back-to-stock-repair-system.225170/#post-
  2. guando
    Eclair Apr 27, 2015
    guando , Apr 27, 2015 :
    Hi, I followed your instructions and I receiveda confirmation message saying 'Bootloader locked' Stock CM11s Installed successful but the phone won't power up. I've tried volume up and power as well but it's not responding at all. Any ideas?
  3. XvEricXv
    Cupcake Apr 28, 2015
  4. imb4uin
    imb4uin , Apr 28, 2015 :
    Did this method work for anyone? or does it just put your phone into brick mode?
    Ceasedd, srinivasan_v and geoponic like this.
  5. imb4uin
    Ceasedd likes this.
  6. bakerbarber
    Jelly Bean Apr 28, 2015
    mervivus, ExpatZ, Animalised and 18 others like this.
  7. sagargogia2255
    LKLRoger likes this.
  8. Bvox
    Donut Apr 28, 2015
    Bvox , Apr 28, 2015 :
    I really hate Lollipop but I also really recommend not trying this, unless you have a lot of money to throw around. Thanks for posting this but I'm seeing a lot of people reporting bricked phones... Better wait for more stable solutions.
    Deactivated User likes this.
  9. yongcong
    Gingerbread Apr 28, 2015
  10. pmdsp
    Honeycomb Apr 28, 2015
    pmdsp , Apr 28, 2015 :
    Sorry to hear that, not sure what has gone wrong. This method has helped many people in rollback, even though your phone is bricked its easy to recover and i sure will help you.
  11. pmdsp
    Sorry i will change the subject line soon.
  12. pmdsp
    Rolodex likes this.
  13. marxandengels
    pmdsp likes this.
  14. pmdsp
    Thanks for confirming.
  15. junear
    pmdsp likes this.
  16. pmdsp
    Honeycomb Apr 29, 2015
    pmdsp , Apr 29, 2015 :
  17. Bvox
    Donut Apr 29, 2015
    Bvox , Apr 29, 2015 :
    The issue is more about lollipop than CM, although CM should have done better than just try to release something quickly and loose functionality. Look at what you use in CM11 and check if it's there in CM12. Lollipoo removed rights from apps to enable and disable data, for example. Not even CM profiles work anymore. The icons on the status bar changed now so you can't tell if If cell data on, unless it's being used at the moment you look at it. Recent apps now is just a list of apps that were opened at some point, not a list of active apps and the list goes on. That's a deal breaker for me. Last time CM broke something like that (bluetooth a while ago) it took 6 months for it to be fixed.
  18. pmdsp
    I tested it before publishing it was working fine for me. Thanks for confirming.
  19. pmdsp
    Random instructions? You either flash it manually by inputing each commend or let the BAT file do it for you, this is the correct method.
    Bvox likes this.
  20. Deactivated User
    Apr 29, 2015
    pmdsp likes this.
