15
Rollback to CM11s from CM12 with a single click.
  1. tarana2000
    Froyo May 10, 2015
    tarana2000 , May 10, 2015 :
    Where?? I am unable to find this option ?!
  2. ImGrass
    Donut May 10, 2015
  3. the_jay
    Donut May 11, 2015
  4. johny.one
    Gingerbread May 11, 2015
  5. Liamv4696
    Donut May 11, 2015
    Liamv4696 , May 11, 2015 :
    My drivers dont install for some reason when the phones in fastboot. Been trying different methods for hours now. Still no solution, stuck with this piece of shit OS
  6. smvdraj10
    Cupcake May 12, 2015
    smvdraj10 , May 12, 2015 :
    HI,
    I have followed your procedure finally i got " 'Bootloader locked' Stock CM11s Installed successful" even my phone not starting, what to do please help me to start the phone.
    Thanks,
    Deepak
  7. pmdsp
    Honeycomb May 14, 2015
    pmdsp , May 14, 2015 :
    Search on youtube about fastboot driver oneplue one.
  8. pmdsp
  9. DavidBoyee
    Gingerbread May 15, 2015
    DavidBoyee , May 15, 2015 :
    Hey so all this seemed to do was wipe my phone and reflash CM12s?
    Edit: So I did it again, and now I'm back on 11s. Thanks!
  10. faizuddin
    Cupcake May 15, 2015
    faizuddin , May 15, 2015 :
    Thanks so much. Worked very well. Adding some additional points. Might come in handy for someone.
    1. Its better to backup
    2. Perform a factory reset to CM 12
    3. Then proceed with the steps
    Just saying...
  11. faizuddin
    Try the Google USB driver. Worked for me.
  12. Christian_yn
    Ice Cream Sandwich May 15, 2015
  13. johny.one
    johny.one , May 15, 2015 :
    Backup your personal pics and other files or contacts is absolutely necessary. But no need for a factory reset, because the process will wipe out everything existing on the device first before installing the stock CM11S rom.
  14. pmdsp
    Honeycomb May 16, 2015
    pmdsp , May 16, 2015 :
    I own a mac and i have windows in bootcamp. windows 10 preview is free at the moment.
    Christian_yn likes this.
  15. madhavanng
    Donut May 16, 2015
    madhavanng , May 16, 2015 :
    Worked well for me.. Thanks in tons for clear instructions in detail.. CM12 was disaster for me.Back to 11 Now ..
  16. s737500
    Cupcake May 16, 2015
    s737500 , May 16, 2015 :
    This works great thank you.
    Messed up a little because of its the firsttime I try to mess with this....but you learn all the time :)
    Amaizing that downgrading is such a fantastic upgrade :)
  17. Christian_yn
    Ice Cream Sandwich May 16, 2015
    Christian_yn , May 16, 2015 :
    Thanks a lot. Worked like a charm. So glad I'm back in CM11 again :):):)
  18. paulprajan
    Cupcake May 17, 2015
    paulprajan , May 17, 2015 :
    This is the first time I am doing anything out of stock. CM 12 was giving me Battery issues and slight heating problems. CM 11 was smooth. While following the process the phone got bricked. The post in this forum helped a lot. Sweated a bit but now the phone is back to CM 11. I don't know when the flashing was done. Suddenly the phone switched on with the CM11 starting screen.
    Thanks guys for the wonderful effort and patience for explaining.
    Cheers. Hope Oneplus can sort out the problems and geta good Lolipop version.
  19. sahajo_84
    Cupcake May 18, 2015
    sahajo_84 , May 18, 2015 :
    Thanks for the video. I could follow upto the fastboot mode. What is the recovery mode, how to put the phone in the recovery mode. please advice.
  20. sahajo_84
    I have tried to rollback to CM11 using attached instruction, but failed.
    My phone condition : I tried to install CM11 using the TWRP, the file unzipped successfullly, but the installation failed. Now my device when turned on always goes to TWRP screen. I can go into the fastboot mode.
    Please guide me how to recover back
    1. How to make sure all the drivers are installed correctly
    2. Do I need to install CM11 firmware
    3. If yes, please let me know how to install firmware
    4. Can I install CM11 using your batch file
