6
[ROM][5.1] CyanogenMod 12 Builds [ GCC 4.9 and GCC 5.1][Full -O3]
  1. pablomoreno
    Lollipop Moderator May 15, 2015
    pablomoreno , May 15, 2015 :
    Versione unofficial della cm 12.1 compilata da jgcaap
    Features:
    Updated SQL to 3.10.0.2
    Optimized SQL code for faster Read/Write
    SuperUser
    Camera Next
    New Kernel
    Improved Code of frameworks
    Optimized Build with O3 4.9 GCC for For ROM and 5.1 Linaro GCC for Kernel
    Optimizations based on Just Archi v4
    Improved sound with speex resampler
    Improved bionic with many optimized libraries (faster rom)
    Translation to Russian (if needed)
    More than 100 mem fixes not included on cm builds
    Alot of aliasing fixes and code ready for new standards compilling (better)
    F2FS ready for data and cache
    Compiled ART, system core, frameworks base with 5.1 gcc for better performance
    Wake Blocker added.
    Discussione ufficiale su XDA:
    http://forum.xda-developers.com/oneplus-one/development/rom-cm-12-builds-t3045053/page135
    Download Rom:
    https://basketbuild.com/filedl/devs?dev=jgcaap&dl=jgcaap/CM/cm-12.1-20150525-jgcaap-bacon.zip
    Download Gapps:
    https://basketbuild.com/filedl/devs..._mini_gapps.BETA.5.1.x.build.0.x-20150421.zip
    Gapps alternative suggeritemi da @AlessioRapisarda001:
    http://www.slimdevs.com/Gapps/Lollipop/5.1/
    https://basketbuild.com/filedl/devs?dev=jgcaap&dl=jgcaap/jgcaapgapps20150523.zip
    Firmware da flashare qualora si provenga da rom non cm 12:
    https://basketbuild.com/filedl/devs?dev=jgcaap&dl=jgcaap/OnePlusFirmware.zip
    La versione della rom che troverete nel link sopra riportato è la versione stabile settimanale,
    se preferite testare le nightly potrete trovarle qui:
    http://www.drdevs.com/devs/jgcaap/oneplus/
    Per l'installazione solite procedure che di seguito riporto:
    - Copia di backup della vostra attuale rom (per eventuale ripristino in casodi problemi)
    - Download della Rom
    - Download delle Gapps
    - Avvio in recovery:
    - wipe cache
    - wipe dalvik
    - wipe system (se si proviene da altra Rom e non si tratta di aggiornamento da versione precedente della stessa Rom)
    - wipe data (se si proviene da altra Rom e non si tratta di aggiornamento da versione precedente della stessa Rom)
    - flash firmware (se si proviene da altra rom non cm12)
    - flash Rom
    - Flash Gapps
    - riavvio
    Divertitevi!!
    AlexM, giuliorenault, ELGeKo and 3 others like this.
  2. Ileopsoas
    Gingerbread May 15, 2015
    Ileopsoas , May 15, 2015 :
    La sto provando da qualche ora, sembra fluida e reattiva ma a discapito della batteria
  3. Maury74rm
    Marshmallow May 15, 2015
  4. AlessioRapisarda001
    Honeycomb May 16, 2015
    AlessioRapisarda001 , May 16, 2015 :
    La miglior ROM per opo! Nell'ultima nightly del 15/05 hanno tolto un processo della Qualcomm che prendeva il 10% della batteria e alcune piccole modifiche al kernel. Inoltre hanno fatto un "Resync della CM" (non ho capito cosa vuol dire). La prossima build avrà un minore drain della batteria. Questo l'ho tradotto dal post di jgcaap.
    Se volete avere ogni aggiornamento andate sul thread ufficiale su xda: http://forum.xda-developers.com/oneplus-one/development/rom-cm-12-builds-t3045053/page135
    @pablomoreno invece di mettere quel link della gapps metti quello in cui vengono aggiornate ovvero: http://www.slimdevs.com/Gapps/Lollipop/5.1/
    Consiglio di mettere l'AK Kernel o il Boeffla :) Mettete anche dei "build.prop tweaks" e L Speed Mod (Una mod che aggiunge tweaks come zipalign e altro. Purtroppo a ogni aggiornamento della rom si toglie) che il telefono diventa super veloce
    Vi do i miei build.prop tweaks (se ne metterò altri postero un altro post:
    # Better Responsiveness & Speed
    windowsmgr.max_events_per_sec=90
    ro.max.fling_velocity=12000
    ro.min.fling_velocity=8000
    ro.min_pointer_dur=8
    touch.pressure.scale=0.001
    # More RAM
    persist.service.pcsync.enable=0
    persist.service.lgospd.enable=0
    #Disable Kernel Error Checking
    ro.kernel.android.checkjni=0
    ro.kernel.checkjni=0
    ro.config.nocheckin=1
    # Reduce dial-out time
    ro.telephony.call_ring.delay=0
    ring.delay=0
    #Better signal reception
    persist.cust.tel.eons=1
    ro.config.hw_fast_dormancy=1
    ro.ril.enable.amr.wideband=1
    #For Sensor Sleep Control
    ro.ril.sensor.sleep.control=1
    # Dialing Tweaks
    ro.lge.proximity.delay=25
    mot.proximity.delay=25
    # Video Acceleration Enabled And HW debugging
    video.accelerate.hw=1
    debug.sf.hw=1
    debug.performance.tuning=1
    debug.egl.hw=1
    debug.composition.type=gpu
    # 3G signal and speed tweaks
    ro.ril.hsxpa=3
    ro.ril.gprsclass=10
    ro.ril.hep=1
    ro.ril.enable.dtm=1
    ro.ril.hsdpa.category=12
    ro.ril.enable.a53=1
    ro.ril.enable.3g.prefix=1
    ro.ril.htcmaskw1.bitmask=4294967295
    ro.ril.htcmaskw1=14449
    ro.ril.hsupa.category=7
    ro.ril.hsdpa.category=10
    ro.ril.enable.a52=1
    ro.ril.set.mtu1472=1
    persist.data_netmgrd_mtu=1482
    persist.data_netmgrd_nint=8
    ro.use_data_netmgrd=true
    ro.ril.enable.dtm=1
    ro.ril.def.agps.mode=2
    ro.ril.def.agps.feature=1
    ro.ril.enable.gea3=1
    ro.ril.enable.fd.plmn.prefix=23402,23410,23411
    # Smoother video streaming and tweak media
    media.stagefright.enable-player=true
    media.stagefright.enable-meta=true
    media.stagefright.enable-scan=true
    media.stagefright.enable-http=true
    media.stagefright.enable-aac=true
    media.stagefright.enable-qcp=true
    media.stagefright.enable-record=false
    # Game tweaks
    persist.sys.NV_FPSLIMIT=60
    persist.sys.NV_POWERMODE=1
    persist.sys.NV_PROFVER=15
    persist.sys.NV_STEREOCTRL=0
    persist.sys.NV_STEREOSEPCHG=0
    persist.sys.NV_STEREOSEP=20
    persist.sys.purgeable_assets=1
    # Qualcomm tweaks
    com.qc.hardware=1
    debug.qc.hardware=true
    debug.qctwa.preservebuf=1
    debug.qctwa.statusbar=1
    # System Tweaks
    ro.HOME_APP_ADJ=1
    ro.mot.eri.losalert.delay=1000
    ro.config.hw_quickpoweron=true
    # Better image quality, lower performance.
    persist.sys.use_dithering=1
    # Saves some battery without reducing performances
    power.saving.mode=1
    pm.sleep_mode=1
    ro.ril.power_collapse=1
    ro.vold.umsdirtyratio=20
    ro.config.hw_power_saving=true
    # Increase some Performance
    ro.secure=0
    persist.sys.use_16bpp_alpha=1
    ro.product.gpu.driver=1
    debug.gr.swapinterval=1
    debug.kill_allocating_task=0
    ENFORCE_PROCESS_LIMIT=false
    hw3d.force=1
    ro.debuggable=1
    ro.wmt.blcr.enable=0
    Vi basterà modificare il build.prop con un file manager con accesso root aggiungendo queste stringhe e infine riavviare. Se volete cercate la linea wifi.supplicant_scan_interval e accanto a = mettete un numero a 300 a quello che volete(io ho messo 500)
    AlexM, Creker94 and pablomoreno like this.
  5. ELGeKo
    ELGeKo , May 16, 2015 :
    Ho appena installato la rom ma non riesco ad avere l'accesso ai root...Che faccio?
  6. pablomoreno
    Lollipop Moderator May 16, 2015
    AlexM and ELGeKo like this.
  7. viciovb
    Gingerbread May 16, 2015
    viciovb , May 16, 2015 :
    Nelle ultime nightly del 16 ci sono 2 versioni, qual è la differenza?
  8. pablomoreno
    pablomoreno , May 16, 2015 :
    Non ne ho la minima idea.
    Forse una delle due ha applicazioni con tema dark (la mia è un'ipotesi)
  9. AlessioRapisarda001
    Penso sia quella con "bacon"
    Guarda il thread ufficiale su XDA
  10. AlessioRapisarda001
    Honeycomb May 18, 2015
    AlessioRapisarda001 , May 18, 2015 :
    Nuova stabile :)
    Changelog:
    Reapplied 90 patches over frameworks/base and AV (many memfixes)
    Improved coding to be built with new Standards at frameworks/base and av
    Reverted touchscreen thanks to @tiny4579 for discovering this
    Ready for new firmware , tested.
    Added wakelock blocker
    Synced with CM changes 18/05/2015
  11. Spigolon97
    Spigolon97 , May 18, 2015 :
    ci sono altri link per il dl ? basketbuild é lentissimo ( da 3 minuti che ho cliccato e deve ancora caricarmi la pagina )
    edit:
    dopo 15 minuti si e aperta la pagina , ma il download non va.. e arrivato a 96kb e si e fermato..
  12. AlessioRapisarda001
    Anche a me BasketBuild, mentre per esempio DrDevs funzion a benissimo (entrambi hanno Peer5)
    Ho chiesto già, forse dalle prossime build stabili le inseriranno la
  13. sono80mb
    Donut May 18, 2015
    sono80mb , May 18, 2015 :
    Io ho l ultima versione di cm12 ( tas17L). Basta wipe chace e dalvik oppure devo fare anche gli altri? Grazie
    tichetta likes this.
  14. tottina84
    Donut May 18, 2015
    tottina84 , May 18, 2015 :
    Ho messo oggi questa ROM..ma apparte che la tastiera si blocca in modo anomalo..il segnale é veramente pessimo..succede anche a voi?io ho tim e ho già messo in wap
  15. AlessioRapisarda001
    Honeycomb May 19, 2015
    AlessioRapisarda001 , May 19, 2015 :
    Tutti
    Quella che hai tu è la CM12S (a quanto pare) quindi devi fare un Clean Flash
    La tastiera a me non si blocca
    Il segnale per me(Sono 3 ITA) è eccezionale
  16. Spigolon97
    Honeycomb May 21, 2015
    Spigolon97 , May 21, 2015 :
    A me dopo un giorno e mezzo di utilizzo , usando avvio rapido , l ho spento per l ennesima volta.. Ma non é più ripartito , schermata cyanogen all infinito... Ho riflashato la ROM con wipe system cache e dalvkik ma niente, ho dovuto fare anche wipe data , ora ho la 12s...mi piaceva come ROM , come mai é successo? ( mi é successo lo stesso con color OS 2.056 beta) , avevo l speed , kernel stock , e le modifiche al build prop
  17. ELGeKo
    ELGeKo , May 21, 2015 :
    Il problema sta nell'avvio rapido, in molte rom mi è capitato il tuo stesso priblema, infatti non lo attivo più ormai. Cmq sai se con l'ultima versione stabile funziona Clash of clans?:rolleyes:
  18. AlessioRapisarda001
    AlessioRapisarda001 , May 21, 2015 :
    "Alright guys, i was having lunch and having a look at google code. it seems that CM roms is far behing compared to AOSP code. That's why many of us is prefering roms AOSP like and say that they get a better experience. ART has a bunch of bug fixing and optimize code. I can't understand the real reason why CM is not including this stuff. So my next goal for our rom will be slowly merging ART changes into our ROM.
    I am finishing now a build on changes which were on bionic level. (is not much, also CM is behind but the code seems to be a bit diferent the way it is structured.)
    Will give news on saturday , after that you'll have one of the best roms around here , which will be pretty advanced compared to stock CM and with a mix of optimized AOSP code+Linaro. After i'll be offline for this, as i'll be turning off myself to only study (will be 4 intensive weeks). So do not expect me on replying or anything, or even giving more updates during that time (but i'll try if CM puts important stuff)
    Cheers."
    (Detto da jgcaap, se non ci credete controllate la pagine 160 del thread su XDA)
    @pablomoreno sul primo post inserisci questo:
    SuperUser
    Camera Next
    New Kernel
    Wake Blocker added.
    Sul principale c'è quello "vecchio"
    Le GApps che ti ho suggerito sono le Slim aggiornate xD
    tichetta and AlexM like this.
  19. Spigolon97
    Non saprei , non ci gioco...
  20. AlessioRapisarda001
    Honeycomb May 24, 2015
    AlessioRapisarda001 , May 24, 2015 :
    NUOVA BUILD STABILE!! https://basketbuild.com/filedl/devs?dev=jgcaap&dl=jgcaap/CM121/cm-12.1-20150524-jgcaap-bacon.zip
    Compiled 100% with GCC 5.1 AOSP+Linaro Patches 5.1 (UBER Tool chains)
    Reorganized a lot optimizations, we have on this build Krait Optimizations, Qualcomm Bionic Optimizations (study best way to implement NEST and Graphite Optimizations, only after exams)
    All C++ code is compiled with new gnu++11 Standards
    Revert "bluedroid: Support dynamic A2DP stream parameters" as it seems to improved Bluetooth experience. (please test)
    Added some of google fixes all around the build, cherry-picked directly from AOSP.
    Disabled a lot of debug options, for performance and battery life (Unless you are a dev you don't care about this part)
    Improved ART for performance.
    Improved Bionic for performance.
    Improved frameworks/base for performance and also some more bug fixing included.
    Improved Audio Quality commits, after rebased, new sampler seems to be working 100%.
    Added on kernel level options necessary for things to work properly with ROM, so that you almost get no errors.
    Synced with CM code on day 23/05/2015 (nothing special was added)
    Ora la rom è FULL GCC 5.1 UBER! (AOSP+LINARO)
    C'è anche una gapps fatta da lui (a quanto ho capito): https://basketbuild.com/filedl/devs?dev=jgcaap&dl=jgcaap/jgcaapgapps20150523.zip
    "This needs testing . Basically was a rebased SLIM GAPPS and changed GMS core with version 430. Needs System wipe at least."
    Consiglio di flashare prima la CM12.1 Ufficiale per prendere l'ultimo firmware disponibile, poi rifare tutti i wipe e flashare la CM12.1 by jgcaap
    AlexM and giuliorenault like this.
