92
[ROM] [6.0.1] Unofficial CyanogenMod 13
  1. Grarak
    Recognized developer Recognized Developer Jun 14, 2016
    Grarak , Jun 14, 2016 :
    CyanogenMod 13 is a free, community built distribution of Android 6.0.1 (Marshmallow) which greatly extends the capabilities of your phone.
    This is the unofficial build of CM 13 for the OnePlus 3 (all variants).
    OnePlus warranty covers software modifications!
    Downloads:
    ROM:
    https://basketbuild.com/filedl/devs...lus3/cm-13.0-20160703-UNOFFICIAL-oneplus3.zip
    Recovery:
    https://basketbuild.com/filedl/devs?dev=Grarak&dl=Grarak/oneplus3/recovery.img
    Sources:
    https://github.com/CyanogenMod/android_kernel_oneplus_msm8996
    https://github.com/CyanogenMod/android_device_oneplus_oneplus3
    https://github.com/TheMuppets/proprietary_vendor_oneplus
    https://github.com/CyanogenMod/android_device_oppo_common
    https://github.com/CyanogenMod/android_device_qcom_common
    https://github.com/CyanogenMod/android_vendor_nxp-nfc_opensource_Nfc
    https://github.com/CyanogenMod/android_vendor_nxp-nfc_opensource_frameworks
    https://github.com/CyanogenMod/android_vendor_nxp-nfc_opensource_libnfc-nci
    Installation instructions:
    1. You must unlock your bootloader via fastboot.
    2. You must have a custom recovery installed (link above)
    3. Fully wipe your device from Recovery if you are not coming from CM13.0 already.
    4. Flash the downloaded ROM
    5. Locate 6.0 Gapps via a quick Google search. (Make sure it‘s arm64)
    6. Reboot into recovery and install.
    Don‘t flash gapps after you booted up CM 13! This will kill your device. If you want gapps,
    then flash it right after you wiped your phone and flashed CM 13.
    Known issues:
    • MSM8996: It‘s a new platform. Don‘t expect that CM 13 will run as good as stock
    • Dash charge: Does not work, blame OnePlus for not releasing its sources in kernel.
    Encryption:
    Currently encryption is forced on stock ROM, but not on CM 13. If you want to get rid off encryption, then reboot to fastboot and exectue:
    fastboot format userdata
    This will wipe your data partition, including storage!
    Changelog:
    20160703:
    • Add F2FS support
    • Fix VoLTE
    20160619:
    • Add autodoor mode in livedisplay
    20160618:
    • Fix no sims get detected when both sim cards are inserted at boot
    20160614:
    • Initial release
    Credits:
    • LG G5 devs, for their initial CM bringup to the MSM8996 platform
    • OnePlus, for the actual phone and the engineers helping me with sorting out few issues
    • Every CM contributor
  2. Naman Bhalla
  3. TiggaPlease
    Gingerbread Jun 14, 2016
    indojam and impure like this.
  4. Magnetic Nerd
    Jelly Bean Jun 14, 2016
    indojam likes this.
  5. jpswer
    jpswer , Jun 14, 2016 :
    Woah amazing! I guess that means you've got a custom recovery too. The OnePlus 3 is definitely going to be the most developer friendly device at this rate!
    Tarfex likes this.
  6. khanhee
    Eclair Jun 14, 2016
    khanhee , Jun 14, 2016 :
    Thanks Grarak :). FYI, as per TechnoBuffalo's OnePlus 3 video, bootloader is unlocked out of the box.
    impure likes this.
  7. tobias14
    Ice Cream Sandwich Jun 14, 2016
  8. besweeet
    Eclair Jun 14, 2016
  9. NisseCool
    Honeycomb Jun 14, 2016
  10. Thecrazyskull
    Thecrazyskull , Jun 14, 2016 :
    Gonna be up real soon as well
  11. Magnetic Nerd
  12. TheCrazyLex
    TheCrazyLex , Jun 14, 2016 :
    Soon ^^
    peyo likes this.
  13. Adam Krisko
    NA Community Consultant Staff Member Jun 14, 2016
    Adam Krisko , Jun 14, 2016 :
    It's coming very soon.
  14. mido25
  15. Two
    Two , Jun 14, 2016 :
    Wow that was fast... I'm more likely to buy it if there is support for CM13 out of the box...
    But first, let's see how the remaining issues get resolved.
  16. Benjos
    Benjos , Jun 14, 2016 :
    Indeed I am very excited credits to the developer
  17. Magnetic Nerd
    Magnetic Nerd , Jun 14, 2016 :
    PA being available when I get the phone in my hands would be amazing. I'm all for Paranoid Android and always have been.
    TheCrazyLex likes this.
  18. DannyM93
  19. dinjesk
    KitKat Jun 14, 2016
    indojam likes this.
  20. marinobiagio
    KitKat Jun 14, 2016
    marinobiagio , Jun 14, 2016 :
    Incredible! One years for CM on OP2 few housr for OP3! LOL Good job one plus for helping devs.. and fuc*ing awsome job (as usual) @Grarak !
    gaster, Kaaylim and sm_ashiq like this.
