92
[ROM] [6.0.1] Unofficial CyanogenMod 13
  1. Shutts318ci
    Froyo Jul 11, 2016
    Shutts318ci , Jul 11, 2016 :
    Thanks for this. So am I right in assuming that in order to install cyanogen that I have to root the phone? If so when I install cyanogen, will this mean nfc etc won't work? Or does installing cyanogen un-root it? Apologies for these noob questions :-/
  2. rclotz
    Honeycomb Jul 12, 2016
    rclotz , Jul 12, 2016 :
    No problem - everyone had started with questions :)
    For installing another ROM it is necessary to unlock the Bootloader. Please keep in mind that will wipe your phone completely. So first of all backup your data (pictures, etc.)
    When you install Cyanogenmod you will have root access automatically. Just activate it in Developer Options.
    And NFC will work.
    Currently Dash Charge won't work on Cyanogenmod but I am pretty sure that this will be fixed with the official Cyanogenmod nightlies.
    So yeah, unofficial nightlies are running fine but.... these are nightlies and under development ;)
  3. FB179
    FB179 , Jul 12, 2016 :
    Cant find it, even in developper options.
    WTF are you talking about?
  4. teddybear3k
    Cupcake Jul 12, 2016
  5. FB179
    techygeek likes this.
  6. jens74
    jens74 , Jul 12, 2016 :
    it only says MS and CM have signed a partnership, that will make it possible for CM to have native MS applications in the rom. If I have translated it correctly.
    RoggaRolla likes this.
  7. masaga91
    Gingerbread Jul 13, 2016
    masaga91 , Jul 13, 2016 :
    Come on guys you're confusing cyanogen and cyanogenmod, there not the same thing, cyanogen signed the agreement not cm
  8. matssa
    Ice Cream Sandwich Jul 13, 2016
    matssa , Jul 13, 2016 :
    Yes you are right, but it only (should in fact) concern CYANOGEN, not CYANOGENMOD. The first (CYANOGEN) supply phones with their official ROM (and so has partnerships with companies, etc...). CYANOGENMOD is open source and doesn't have ANY link or partnerships. CYANOGEN is based on CYANOGENMOD but the objective is different since it is a company.
  9. tabs78
    tabs78 , Jul 13, 2016 :
    hi, i tried resurretion rom and this.
    I prefer this because has less bugs.
    but i have same questions:
    1) the defualt dpi on oxygen how much is?480dpi like this rom are a prblem for display?and battery?
    2) the ressuration for my use has 1,5 hours of sot more...is incredible!which is the secret?
  10. masaga91
    Gingerbread Jul 14, 2016
    masaga91 , Jul 14, 2016 :
    It's easy, you basically need to find a Pikachu and scratch is belly, the electrostatic energy will recharge your phone, and with that cm a rr will have the same sot
  11. Shutts318ci
    Froyo Jul 14, 2016
    Shutts318ci , Jul 14, 2016 :
    T
    Thanks mate, gonna go for it tonight/tomorrow. How long does the process take?
  12. Shutts318ci
    Froyo Jul 14, 2016
  13. Shutts318ci
    Froyo Jul 14, 2016
    ok so I managed to get into fastboot, run the oem unlock command and rebooted, then tried to send the recovery image over but got an error that partition flashing is not allowed?
  14. matssa
    Ice Cream Sandwich Jul 14, 2016
    matssa , Jul 14, 2016 :
    I suggest you use the toolbox, it can be found on XDA. It does everything for you.
    Shutts318ci likes this.
  15. rclotz
    Honeycomb Jul 14, 2016
    rclotz , Jul 14, 2016 :
    After running the OEM unlock command you have to confirm this step on your phone.
    There will be a message displayed. That's necessary! Otherwise your bootloader is not unlocked.
  16. Shutts318ci
    Froyo Jul 15, 2016
    Shutts318ci , Jul 15, 2016 :
    Once you have flashed CM and it's al sorted, are you able to unroot/re-lock the bootloader? I have an app that I need that won't install due to it being rooted.
  17. rclotz
    Honeycomb Jul 15, 2016
    rclotz , Jul 15, 2016 :
    I never did that so I am not sure. But I know, that some people don't recommend to lock the bootloader again due to some errors.
    And you should keep in mind that this is an unofficial cm version and I absolutely doubt that it is without bugs. It has to be enhanced in the next months and then you have to flash again.
    For example I am back to Oxygen because I had issues with the mobile connection. Sometimes the phone lost the connection and has to be rebooted. The last time I got no connection also after rebooting.
    So that's a no-go and I switched back to oxygen.
  18. Shutts318ci
    Froyo Jul 15, 2016
    Ahh ok, I flashed because some remnants from my opo cm install when restored, corrupted the dnd function in oxygen. I may need to flash back to oxygen and just not restore my settings. Blocking callers isn't in oxygen that I can find either.
    Would an official version be "un rooted"?
  19. rclotz
    No. CM Roms are always pre-rooted as far as I know.
  20. techygeek
    Ice Cream Sandwich Jul 15, 2016
