92
[ROM] [6.0.1] Unofficial CyanogenMod 13
  1. Shutts318ci
    Froyo Jul 15, 2016
    Shutts318ci , Jul 15, 2016 :
    So my work app will never work unless I flash back to stock oxygen?
  2. stephenboyo
    KitKat Jul 16, 2016
  3. benwalburn
    Froyo Jul 16, 2016
    benwalburn , Jul 16, 2016 :
    It's not dreadful or news. It's a year old article about Cyanogen Inc, not CyanogenMod.
  4. rclotz
    Honeycomb Jul 16, 2016
    rclotz , Jul 16, 2016 :
    Good question.
    I think you only can test that. In CM you can deactivate root in developer options.
    So maybe it works.
  5. stephenboyo
    KitKat Jul 16, 2016
    stephenboyo , Jul 16, 2016 :
    Oh OK cool
  6. NaterTots
    Jelly Bean Jul 17, 2016
    NaterTots , Jul 17, 2016 :
    CM isn't pre rooted.
    It has root built in, but your phone is only rooted if you turn it on.
    If you don't turn it on then your work app will most likely still work as it should.
  7. MrPinky
    Donut Jul 17, 2016
    MrPinky , Jul 17, 2016 :
    Sorry if this is a dumb question but I'm a bit out of the loop with custom ROMs having run stock for quite some time, but I'm now considering CM13 on my new OP3 to fix the scheduled DND problem in OOS.
    If I install this CM13 build and keep encryption enabled, can I get a restorable backup:
    1. In TWRP
    2. Via an online nandroid
    If so, is there anything I need to be aware of in terms of how the encryption would affect a subsequent restore of that backup.
    Thanks
  8. stephenboyo
    KitKat Jul 17, 2016
    stephenboyo , Jul 17, 2016 :
    Your dash charging won't work on CM13, otherwise it's a brilliant ROM . I achieved 152,000 on antu tu benchmark which is the highest score and 12k higher than stock Oxygen 3.2.1, so great ROM for speed , downside for me was absence of dash charging but I understand this will version of cm13 will be upgraded.
    techygeek likes this.
  9. Shutts318ci
    Froyo Jul 17, 2016
    Shutts318ci , Jul 17, 2016 :
    So an official cm should be ok? I didn't enable root I just followed the instructions from the beginning of this thread.
  10. Shutts318ci
    Froyo Jul 17, 2016
    Root access says disabled, is that the option you meant?
  11. rclotz
    Honeycomb Jul 18, 2016
    rclotz , Jul 18, 2016 :
    Yes.
    It is in Developer Options.
    In Phone Options you have to tap a few times on the Build Number then you have access to the Developer Options where you can enable or disable root functionality.
  12. Coldbird
    Gingerbread Jul 18, 2016
    Coldbird , Jul 18, 2016 :
    Most of those anti root applications deny access to their content solely based on the fact that you are running CyanogenMod.
    To them it's not about whether you currently have root, but rather whether you can easily enable it or not, which you can on CyanogenMod.
    Ironically, if you want to run those on a non-rooted CyanogenMod installation, you will need to root first and install a root cloak module of some kind to hide your root capabilities.
    The irony...
  13. Shutts318ci
    Froyo Jul 18, 2016
    Shutts318ci , Jul 18, 2016 :
    What us the difference with cm on the opo then as I don't have the same problem on that ? Annoying.
  14. Coldbird
  15. techygeek
    Ice Cream Sandwich Jul 18, 2016
  16. vijaywidluv
    vijaywidluv , Jul 18, 2016 :
    the day it starts supporting dash charger, I will be on this ROM without any second thought. this ROM was my daily driver on my op2 and loved it. Grarak does the wonder every time and I believe he will make it work very soon or may the official very soon . till than will be on stock. I do visited here daily by the way just to check the progress of this ROM.. thank-you Grarak
    iblesq likes this.
  17. Shutts318ci
    Froyo Jul 18, 2016
    Does anyone know how to regress back to oxygen?
    @Grarak , would you know if there is a difference between the cyanogen for the oneplus one and your cm13? Just that for some reason maas360 didn't complain on my opo but it does with cm13 :confused: thanks.
  18. masaga91
    Gingerbread Jul 19, 2016
    masaga91 , Jul 19, 2016 :
    OPO is running cyanogen OS not cm...
    Shutts318ci likes this.
  19. Shutts318ci
    Froyo Jul 19, 2016
    Shutts318ci , Jul 19, 2016 :
    That would explain it. I assume there won't be a cyanogen so for the 3?
  20. Shutts318ci
    Froyo Jul 19, 2016
