92
[ROM] [6.0.1] Unofficial CyanogenMod 13
  1. AloCubano
    Gingerbread Jul 27, 2016
    AloCubano , Jul 27, 2016 :
    Hi
    I tried to flash the latest build nightly CM13 and my phone doesn´t boot ( i tried dirty and clean flash , updating from previous buid ) and nothing does any one have the same problem or knows what is the problem?
    tks
  2. RoggaRolla
    Honeycomb Jul 28, 2016
    RoggaRolla , Jul 28, 2016 :
    0726 didnt work for me either, but 0728 runs perfect.
    + Xposed v86 + MonoSound.zip
    AloCubano likes this.
  3. shailinder
    Froyo Jul 28, 2016
    shailinder , Jul 28, 2016 :
    Need support. I have wiped current OS which was CM13 unofficial and this nightly is not working...So effectively I do not have an OS in my phone...:(
    I am able to go to recovery mode via TWRP and see CM 13 nightly and GAPPS but cannot install them...Error " E:Error executing updater binary in zip "/sdcard/cm-13.0-20160728-NIGHTLY-oneplus2.zip' Error flashing this file...
    what can I do ?
  4. rclotz
    rclotz , Jul 28, 2016 :
    Flash the correct zip file. You mentioned "........ oneplus2.zip" but you need ....oneplus3.zip
    Or is it a typo?
    luukbernardes and NaterTots like this.
  5. AloCubano
    Gingerbread Jul 29, 2016
    AloCubano , Jul 29, 2016 :
    Thanks.
    it´s solved it was an encryption problem.
    is working fine now.
    cps
    RoggaRolla likes this.
  6. urvian00b
    Gingerbread Aug 3, 2016
    urvian00b , Aug 3, 2016 :
    Is there dash charging on the CM nightlies? I was at 10% and an hour later I was at 100
  7. masaga91
    masaga91 , Aug 3, 2016 :
    Yes
  8. AloCubano
    Gingerbread Aug 7, 2016
    AloCubano , Aug 7, 2016 :
    How is the CM13 camera working (image quality) comparing with the OOS 3.2.2 , is it better than it was?
  9. cyanogen
    Steve Kondik Aug 9, 2016
    cyanogen , Aug 9, 2016 :
    Hit the scenemode button in the Camera app to use ClearShot and other features. The only feature we don't yet support in the camera is the face beautifier- for some reason the shader fails :(
    Jole7, Kimbo82, farmerjohn and 2 others like this.
  10. dz3n
    Donut Aug 10, 2016
    dz3n , Aug 10, 2016 :
    What is the situation with push notifications on CyanogenMod? Is there the same delay like OOS 3.2.2?
  11. Shutts318ci
    Froyo Sep 1, 2016
  12. DannyM93
    Ice Cream Sandwich Sep 2, 2016
    DannyM93 , Sep 2, 2016 :
    Yep. Been official nightlies for about a month, and we've had a snapshot for about 2 weeks.
  13. Shutts318ci
    Froyo Sep 2, 2016
    Shutts318ci , Sep 2, 2016 :
    I installed yesterdays nightly and it fixed all my issues... woohoo!!
  14. kell
    Gingerbread Sep 12, 2016
    kell , Sep 12, 2016 :
    hey, i installed cm13 with gapps, but i dont have a gallery app now...
    can i go back to recovery and flash cyan apps or will that kill my device?
  15. DannyM93
    Ice Cream Sandwich Sep 12, 2016
    DannyM93 , Sep 12, 2016 :
    If you used Stock Gapps then it will replace your gallery app with Google Photos.
    Also, you're perfectly fine to go back and flash c-apps at any time. You do have to manually mount the system partition though and make sure to allow TWRP to mount system as read/write.
  16. kell
    i downloaded oxygen os gallery app
    only problem is it dont display my photos...
  17. kell
    Gingerbread Sep 14, 2016
    kell , Sep 14, 2016 :
    Can anyone help me?
    I enabled root acces for 2 seconds
    And now pokemon go doesnt work anymore...
    How can i perma.delete root?
    I like root but i like pokemon go more...
  18. DannyM93
    Ice Cream Sandwich Sep 14, 2016
    DannyM93 , Sep 14, 2016 :
    Are you using SuperSU, or the built-in root solution?
    For built-in root, I'm assuming you have gone back into the dev options and disabled it. Beyond that, I don't know how to remove it further. Force close Pkmn Go and reboot your phone and see if that helps.
    For SuperSU, you can try opening the SU app, going to settings, scroll down to cleanup, and select "Full unroot", then reboot.
  19. kell
    I used the build in root
    I disabled it and rebooted but pokemon go still says its incompatible softwate (assuming its the root and not cm13)
    I installed supersu afterwards and did full unroot and the same thing happened :(
  20. kell
    This is the error
    Oh and i checked root checker
    It says not rooted
    So i think the problem is CM13 nightly?!?
