92
[ROM] [6.0.1] Unofficial CyanogenMod 13
  1. Grarak
    Recognized developer Recognized Developer Jun 19, 2016
    Grarak , Jun 19, 2016 :
    How about open the settings app?
    inffy likes this.
  2. Magnetic Nerd
    Jelly Bean Jun 19, 2016
    Magnetic Nerd , Jun 19, 2016 :
    I actually don't have the phone yet (it's arriving tomorrow) I was asking before I got it because I wanted to know before flashing
    Was just a question i'm sorry if it's been brought up before.....
  3. T5620
    Cupcake Jun 20, 2016
    T5620 , Jun 20, 2016 :
    There was a software engineer in OP said they will release the binary rather than the source code later. Have you ever heard about that?
  4. Vatu
    Honeycomb Jun 20, 2016
  5. kell
    Gingerbread Jun 20, 2016
    kell , Jun 20, 2016 :
    Yeah, i just couldt set up my fingerprint and my whole phone was doeing weird
    Im now back on oxygen but still are not happy...
    Everything (whatsapp messages, email and all other kind of notification wont arrive untill i turn on my screen or the app...
  6. matssa
    Ice Cream Sandwich Jun 20, 2016
    matssa , Jun 20, 2016 :
    This is the doze feature. You can turn it off by going in the battery menu, then 3 dots, then optimization, then all apps, then choose your app and deactivate optimization.
  7. matssa
    You understood correctly. If the source isn't released, no one except OnePlus will be able to use it. Apparently, the binaries will be supplied by OnePlus so it will be possible to use it later but impossible to tweek it (logic since the source code can be used by other OEMs).
    When flashing, I had some problems to locate this setting, but i finally found it, so yeah you can flash away, it's there :) plus, you can chose setting for each position instead of swapping.
  8. kell
    Thx it works
    matssa likes this.
  9. DomenicSchaller
    Eclair Jun 20, 2016
  10. cezarvrabie
    Jelly Bean Jun 20, 2016
    cezarvrabie , Jun 20, 2016 :
    You can't turn off doze.
  11. matssa
    You can disable battery optimization per app. You can't turn off Doze on the phone, but you can remove apps from the Doze list.
  12. mwayner
    Lollipop Jun 20, 2016
    mwayner , Jun 20, 2016 :
    Anyone done a comparison with Oxygen? Is it as stable? Is it faster or slower? How does battery life compare?
  13. dr1ftz
    Eclair Jun 20, 2016
    dr1ftz , Jun 20, 2016 :
    Really hoping you guys can get CM to a good stable state soon because I hate Oxygen :(
  14. matssa
    I'm on it and it is pretty stable. Can't say for battery life. Instead of waiting a detailed feedback, I suggest you try it out, you won't regret it. (I can't remember a stabler ROM in so little time).
    mwayner likes this.
  15. dr1ftz
    Eclair Jun 20, 2016
    Will updates be available through CM Updater?
  16. matssa
    Not official ones, I think we may have un official ones but Grarak needs to change the build in order to point somewhere specific for the builds, etc...
  17. masaga91
    masaga91 , Jun 20, 2016 :
    I'll get my op3 between Wednesday and Friday, and the first thing will be flashing cm, will let you know how it goes, battery life and all that
  18. Wahoux
    Lollipop Jun 21, 2016
    Wahoux , Jun 21, 2016 :
    Good battery life!
    But, I have an issue, most of the time, wifi speed is really extremely slow, 20ko/s whereas my regular speed is 450ko/s :(
  19. matssa
    Ice Cream Sandwich Jun 21, 2016
    matssa , Jun 21, 2016 :
    I'm getting some random reboots (not full reboots, only soft reboots) when using Waze and Device only GPS. I'll try to get a log but hard when driving ;)
  20. Wahoux
    Dash charge work for me :eek:
